Klein-Gordon equation and factorization
4 replies · 4K views
parton
Hi!
I read a text were some kind of "Schroedinger-equation" for a neutrino field is being derived. But there is a particular step I do not understand.
Consider a Dirac field [tex]\psi(t, \vec{x})[/tex] of a neutrino, satisfying the Klein-Gordon equation:
[tex]\left( \partial_{t}^{2} + \vec{k}^{2} + m^{2} \right) \psi_{\vec{k}}(t) = 0[/tex]
where the field was expanded in plane waves [tex]\psi(t,\vec{x}) = \psi_{0} e^{i (\vec{k} \cdot \vec{x} - E \cdot t)}[/tex] and the spatial derivatives were already computed.
Furthermore, we assume the high relativistic limes where [tex]k = \vert \vec{k} \vert \gg m[/tex]
Now we can linearzie the equation above using
[tex]\partial_{t}^{2} + \vec{k}^{2} = (-i \partial_{t} + k) (i \partial_{t} + k)[/tex]
Applying only the 2nd factor onto the field [tex]\psi(t,\vec{x})[/tex]
will lead to
[tex]\left \lbrace (-\partial_{t} + k) (E + k) + m^{2} \right \rbrace \psi(t,\vec{x}) = 0[/tex]
Now the following approximaton of the energy-momentum relation is used:
[tex]E = \sqrt{\vec{k}^{2} + m^{2}} \simeq k[/tex]
If we use this approximation in the equation above, we have
[tex]\left \lbrace (-\partial_{t} + k) (2 k) + m^{2} \right \rbrace \psi(t,\vec{x}) = 0[/tex]
which is actually the equation I need.
But my problem is, what happens if I exchange the order in the factorization above:
[tex]\partial_{t}^{2} + \vec{k}^{2} = (i \partial_{t} + k) (-i \partial_{t} + k)[/tex]
Going through the same steps as above I end up with
[tex]\left \lbrace (\partial_{t} + k) (k - k) + m^{2} \right \rbrace \psi(t,\vec{x}) = 0[/tex]
so finally I have
[tex]m^{2} \psi(t,\vec{x}) = 0[/tex]
which does not make sense.
So my question is why is it possible to make the linarization
and why do I have to pay attention to the order of the factors?
I hope somebody could help me.
I didn't read carefully enough to spot where you made the mistake, but I'll tell you the answer; the Klein-Gordan operator acting on a plane wave returns m^2 times the plane wave, even in the relativistic limit. Therefore, no matter what order you do things, you should expect a cancellation between two big numbers (k^2 + m^2) and (-k^2) such that you get the small number m^2.
Thanks for your answer.
I think you mean the d'Alembert operator (the Klein-Gordan operator applied on a free field should return 0).
The equation
[tex]m^{2} \psi(t,x) = 0[/tex]
makes no sense. But I just recognized that if the relativistic limit corresponds to the massless limit, this equation would make sense if we set m=0.
And the other equation (if we exchange the order of the operators) would be
[tex](-\partial_{t} + k) \psi(t,\vec{x}) = 0[/tex]
So if the mass is vanishing in the high relativistic limit there is no contradiction anymore and the order of the operators does not matter.
But nevertheless I am confused. As long as I do not neglect the mass the order is important and depending on it, I find two different equations.
Maybe the "derivation" of the equation
should be considered as some kind of heuristic reasoning to find this "Schroedinger"-equation.
If we write it in the form
[tex]\partial_{t} \psi(t, \vec{x}) = \left( k + \dfrac{m^{2}}{2k} \right) \psi(t,\vec{x})[/tex]
we see that the RHS is just the expansion of the energy in the relativistic limit:
[tex]E = \sqrt{k^{2} + m^{2}} \simeq k + \dfrac{m^{2}}{2k}[/tex]
But this is confusing me, because above I used another approximation:
[tex]E \simeq k[/tex]
So if originally E ~ k is used and therefore, higher order terms
[tex]\mathcal{O} \left(\dfrac{m^{2}}{2k} \right)[/tex]
are neglected why are this higher order terms not neglected in the "Schroedinger" equation too?
Code:
Isn't the basic issue here that, whilst it may be reasonable to approximate k ≈ E when calculating the factor (E + k), doing this is much less so when calculating
[tex](-i\partial_{t} + k) = (k - E)[/tex]
For example, it is often reasonable to say that 1,000,000 + 1,000,001 ≈ 2,000,000, but much less so to suggest that 1,000,001 - 1,000,000 ≈ 0.
If, instead, we use the approximation
[tex]E - k \simeq \dfrac{m^{2}}{2k}[/tex]
then the equation becomes
[tex]\left \lbrace (i\partial_{t} + k) (\dfrac{-m^{2}}{2k}) + m^{2} \right \rbrace \psi(t,\vec{x}) = 0[/tex]
which (unless I've got something wrong here) reduces to
[tex](-i\partial_{t} + k)\ \psi(t,\vec{x}) = 0[/tex]
and doesn't really help here. Actually, I don't really see why the same result should follow regardless of which factor we decide to operate with on the wavefunction first.
(Also, haven't you left out an i that should be before the ∂t in some of your equations?)
Yes, you are right.
I am just confused by the decomposition
If the order is important then how do I know how to decompose the d'Alembert operator in the right way?
How do I know that i should write
and not
Or should I argue that I am intersted in the "difference" between energy and momentum and therefore, need to consider
