Kronecker sum of more than two matrices?
Earthland
The question arises from this quote from wikipedia's article about kronecker product:
Kronecker sums appear naturally in physics when considering ensembles of non-interacting systems. Let Hi be the Hamiltonian of the i-th such system. Then the total Hamiltonian of the ensemble is
I have to write this Htot as a ordinary sum over kronecker products of unity matrix and Hi-s.
Kronecker sum for two matrices is defined as
If A is n × n, B is m × m and Ik denotes the k × k identity matrix.
Well, as I undesratnd, now instead of A and B we have simply Hi and there should be sum kind of sum over i. But the Kronecker sum is defined only for a pair of matrices and it isn't commutative, so the order is important. I tried something like this, for three H-s:
But it doesn't look very elegant and I have no idea if this could be true. Any advice?
The definition is as follows
H_{\text{Tot}} =\left( H_1 \otimes \mathbb{I} \otimes \mathbb{I} \otimes ... \right)+ \left(\mathbb{I} \otimes H_2 \otimes \mathbb{I} \otimes ... \right) + \left(\mathbb{I} \otimes \mathbb{I} \otimes H_3 \otimes ... \right) + ...
Are you sure? Thank you!
Proof:
Kronecker sum is associative.
In other words.
The Kronecker sum of two matrices is, as you wrote,
X=A\oplus B = A\otimes\mathbb{I}_B + \mathbb{I}_A\otimes{B}
Now, since the sum ##A\oplus B## is a matrix, ##X##, the Kronecker sum
Y= X\oplus C = X\otimes\mathbb{I}_C + \mathbb{I}_X\otimes C = (A\otimes\mathbb{I}_B + \mathbb{I}_A\otimes{B})\otimes\mathbb{I}_C + \mathbb{I}_X\otimes{C}
Of course ##\mathbb{I}_X=\mathbb{I}_A\otimes\mathbb{I}_B##, which gives
Y= A\otimes\mathbb{I}_B\otimes\mathbb{I}_C + \mathbb{I}_A\otimes B\otimes\mathbb{I}_C + \mathbb{I}_A\otimes\mathbb{I}_B\otimes{C}
##Z= Y\oplus D = ## Keep going... :)
Thank you very much!
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
