L-Algebra, finding h (unknown in matrix)
  • Thread starter Thread starter viet_jon
    Matrix
viet_jon
say there's a matrix with rows
2 , 3 , h
4, 6, 7
I tried to rref it, but don't know what to do next.
or
v1 = (1, -3, 2)
v2 = (-3, 9, -6)
v3 = (5, -7, h)
the question reads, for what values of h is v3 in span(v1,v2), and for what values of h is (v1, v2, v3) linearly dependent?
I've went over the chapter twice, but still can't find a way to do this. I understand the concept of the chapter (linearly dependency), but it shows no examples of questions like these.
anybody?
I'm desperate.
Ok, we have a matrix given by:
<br /> \left( {\begin{array}{*{20}c}<br /> 1 &amp; 3 &amp; 5 \\<br /> { - 3} &amp; 9 &amp; { - 7} \\<br /> 2 &amp; { - 6} &amp; h \\<br /> \end{array}} \right)<br />
1) In order for v3 to be in the span of {v1;v2}, v3 has to be lineary dependent on v1 and v2, i.e. we want to be able to write it as a linear combination of v1 and v2. When is v3 linearly dependent on v1 and v2?
2) Same as #1, but when is v3 linearly dependent on v1 and v2?
The answer is that each column has to have a leading term after RREF, i.e. the matrix must have a rank of 3. Use this to determine h.
Also, when you have solved #1, then you can see what the coefficients are in the linear combination that makes v3.
I don't think I expressed myself very clearly above. In order for the three vectors v1, v2 and v3 to be linearly independent, no row must consist of entirely zeroes. In this case, the matrix is said to have a rank of 3.
viet_jon said:
or
v1 = (1, -3, 2)
v2 = (-3, 9, -6)
v3 = (5, -7, h)
I hope this is a different problem from the first one you posted in this thread. I don't see any connection between them.
For this problem, v2 = -3 * v1, or equivalently, v1 = -1/3 * v2.
What does that tell you about the linear dependence or independence of these two vectors?
What does that tell you about span{v1, v2}?
For v3 to be in span{v1, v2} there must be constants a and b such that v3 = a*v1 + b*v2. Is there some value of h for which there is a solution to this equation?
Now for the the second question, if you have two vectors that are linearly independent, and you add a third vector, is the new set still linearly independent? Answer: Sometimes it is, and sometimes it isn't. If the new vector is a linear combination of the first two, the new set is linearly dependent. (The new vector is in the span of the first two vectors.) If the new vector is not a linear combination of the first two, the new set is linearly independent. (The new vector is not in the span of the first two vectors.)
If you have two vectors that are linearly dependent, and you add a third vector, is the new set linearly dependent or linearly independent? Answer: The new set is always linearly dependent.
sorry, I am a little slow...I still don't understand. :frown:
the answer in the back, shows no h is possible.
I think it would be easier to understand for me, if we used a question with a definitive answer.
v1 = {1, -1, 4}
v2 = {3, -5, 7}
v3 = {-1, 5, h}
the answer is suppose to be 6.
but how is v2 linearly depdenant on v1? It is not a scaler of it...so doesn't that make it independent?
You're changing vectors on us. Here's what you had in post #2:
v1 = (1, -3, 2)
v2 = (-3, 9, -6)
v3 = (5, -7, h)
In post #7, you have a different set of vectors. Which is the right set of vectors?
For the set of vectors you posted in #2, v2 is a multiple of v1 (and conversely, v1 is a different multiple of v2).
In post #6 I asked some questions. If you answer them, you might understand better what's going on here.
v1 and v2 are linearly dependent.
there are no values...right?
This paragraph I understand pretty well. I still don't know how to find h though.
sorry :smile:
I posted the wrong question in post #2.
v1 = {1, -1, 4}
v2 = {3, -5, 7}
v3 = {-1, 5, h}
I get the jist of your explanation to post #2. But this question... how is v2 linearly depdent on v1? it's not a multiple.
therefore, how can any value for h, make the set of vectors linearly dependent?
Your answers in post 9 were all right, so let's move on to the real problem.
v1 and v2 (from post 10) are linearly independent.
To answer the question about h, you want to find a nontrivial solution for c1, c2, c3 in the equation c1*v1 + c2*v2 + c3*v3 = 0. By nontrivial, I mean a solution other than c1 = c2 = c3 = 0, where at least one of the numbers ci isn't zero.
To do this, form a matrix whose columns are [v1 v2 v3].
Row reduce this matrix as far as you can go. You should end up with a third row that has 0 0 <some expression with h>. What value of h makes that expression equal zero? That's the value of h that makes the three vectors v1, v2, and v3 a linearly dependent set. (We don't say that v3 is "dependent on" v1 and v2.)
I worked this and found that -5v1 + 2v2 + v3 = 0 for the value of h that I found.
