Lagrange optimization: cylinder and plane intersects,
a255c
The cylinder x^2 + y^2 = 1 intersects the plane x + z = 1 in an ellipse. Find the point on the ellipse furthest from the origin.
$f(x) = x^2 + y^2 + z^2$
$h(x) = x^2 + y^2 = 1$
$g(x) = x + z = 1$
$\langle 2x, 2y, 2z \rangle = \lambda\langle2x, 2y,0\rangle + \mu\langle1,0,1\rangle$
This results in the equations:
$2x = 2x\lambda + \mu$
$2y = 2y\lambda$
$2z = \mu$
Then $\lambda = 1$, then $2x = 2x + \mu$, then $0 = \mu$, so then $z = 0$.
Then $x + z = 1$, so $x = 1$.
And then $1^2 + y^2 = 1$, so $y = 0$, so then I conclude that the point where this ellipse is furthest from the origin is $(1,0,0)$.
This is wrong. The answer should be $(-1,0,2)$
You'll have a much better chance of replies if you fix up the Latex. You need to double the dollar signs, or if you don't want an equation on a line by itself replace the dollar sign with a double hash(#).
$g(x) = x + z = 1$
$2y = 2y\lambda$
$2z = \mu$
The equation ##2y = 2y \lambda## implies either ##\lambda = 1## or ##y = 0##.
Note how my LaTeX comes out properly, unlike yours. That is because I used "# # ... # #", but with no space between the two #'s at the start and the end. Had I used $...$ instead it would have come out a mess, like yours. LaTeX/TeX works a bit differently on this Forum than it does in native form.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
