Lagrangian density, regular Lagrangian, E&M
The discussion centers on the use of Lagrangian density, denoted as \(\mathcal{L}\), in the Lagrangian formalism of electrodynamics, specifically for deriving Maxwell's equations. The Lagrangian density allows for the formulation of partial differential equations necessary for field theories, unlike the regular Lagrangian \(L\), which is limited to ordinary differential equations. Additionally, the distinction between Galilean-invariant and Lorentz-invariant theories is not solely based on the choice of \(\mathcal{L}\) but also on the transformation properties of the fields involved.
  • Understanding of Lagrangian mechanics
  • Familiarity with electromagnetic theory and Maxwell's equations
  • Knowledge of partial differential equations
  • Concept of invariance in physics (Galilean and Lorentz)
  • Study the derivation of Maxwell's equations from Lagrangian density \(\mathcal{L}\)
  • Explore the transformation properties of fields in classical field theories
  • Learn about variational principles in continuum mechanics
  • Investigate the implications of Galilean vs. Lorentz invariance in physical theories
Physicists, particularly those specializing in theoretical physics, electromagnetism, and classical field theories, will benefit from this discussion.
HJ Farnsworth
Greetings,
I have two semi-related questions.
1. When making the Lagrangian formalism of electrodynamics, why is it that we use the Lagrangian density [itex]\mathcal{L}[/itex], rather than the plain old regular Lagrangian [itex]L[/itex]? Is this something that is necessary, or is it more that it is just very advantageous for simplicity, etc.? To put it another way, somewhere along the way someone must have been trying to set up E&M using Lagrangians and had some realization where they thought, "this would be much better if I use [itex]\mathcal{L}[/itex] instead of [itex]L[/itex]." What was this realization?
2. For classical field theories using Lagrangian densities in general, does the difference between a Galilean-invariant theory and a Lorentz-invariant theory come purely from the choice of [itex]\mathcal{L}[/itex], and whether that choice (or the resulting equations of motion) are invariant under Galilean transformations or Lorentz transformations? Or, is there instead an axiom of classical field theory that can be altered to differentiate between Galilean- and Lorent-invariant theories?
Thanks for any help that you can give.
-HJ Farnsworth
The plain old regular Lagrangian refers to finite number of variables and leads to finite number of ordinary differential equations.
The purpose of the Lagrangian formalism of ordinary electromagnetic theory is to derive all or at least some of the Maxwell equations. These are partial differential equations for fields. Such equations cannot be derived from finite number of ordinary differential equations.
Similarly to continuum mechanics, it was found that they can be derived from a variational principle where integral of certain quantity ##\mathcal{L}## over space and time plays role. In case of EM theory this quantity is a function of finite number of potentials and field strengths. The quantity
L=\int\mathcal{L}dV
is still called lagrangian, but due to the integral over space it is a functional of the potentials and field strengths so it is not "the plain old regular Lagrangian" in the above sense.
Both ##\mathcal{L}## and ##L## can be used to find the equations for the field.
No. In addition, the transformation properties of the fields have to be assumed. For example, the wave equation for the field ##u##
\frac{\partial ^2u}{\partial t^2} = c^2\Delta u
with ##c## equal to speed of light can be derived from the Lagrangian density
\mathcal{L}=(\partial_t u)^2 -c^2(\partial_k u )(\partial_k u)
Whether the theory is Galilei or Lorentz invariant depends on how ##u## transforms and this cannot be derived purely from the function ##\mathcal{L}##.
Hi Jano,
Great answer, thanks for helping me out!
  • · Replies 26 ·
