Lagrangian in classical mechanics
The Lagrangian in classical mechanics is defined as the difference between kinetic and potential energy, serving as a crucial tool for determining a system's dynamics. Its physical meaning lies in its ability to encapsulate the system's behavior and evolution over time. While some participants question the need for visual analogies, the consensus is that understanding the Lagrangian's role is essential for grasping the underlying physics. The discussion emphasizes the Lagrangian's importance in formulating the equations of motion for mechanical systems. Overall, the Lagrangian is fundamental to the study of classical mechanics.
ghery
Hello:
In Classical mechanics, the lagrangian of a system is defined as the kinetic energy minus the potential energy, but is there any physical meaning of the lagrangian ?, and if there is, What is it?
Regards
What do you mean by physical meaning?
The Lagrangian specifies the physics content of the system, it determines the dynamical evolution of the system.
That's pretty much the definition as I've seen it. Would a visual analogy work better...I'm not sure if I'll do any benefit for you there. lol
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
