Lagrangian mechanics: Bar connected to a spring
The discussion focuses on solving a Lagrangian mechanics problem involving two masses connected by a spring and a rod. The Lagrangian is defined as L = T - V, where T represents the total kinetic energy and V the potential energy. The equations of motion derived using the Euler-Lagrange equations are (m1 + m2) \ddot z = -kz + (m1 + m2) g for vertical motion and \frac{d}{dt}(m2 l^2 \dot \varphi) = 0 for rotational motion. The analysis confirms that the system behaves like a mass on a spring without damping, and the two degrees of freedom are independent.
  • Understanding of Lagrangian mechanics
  • Familiarity with Euler-Lagrange equations
  • Knowledge of kinetic and potential energy concepts
  • Basic principles of angular momentum conservation
  • Study the derivation of Lagrangian mechanics from classical mechanics principles
  • Learn about the application of Euler-Lagrange equations in multi-body systems
  • Explore the implications of conservation laws in mechanical systems
  • Investigate the effects of damping in harmonic oscillators
Students and professionals in physics, particularly those studying mechanics, as well as engineers working on dynamic systems involving springs and rotational motion.
Christoffelsymbol100
Mass 1 can slide on a vertical rod under the influence of a constant gravitational force and and is connected to the rod via a spring with the spring konstant k and rest length 0. A mass 2 is connected to mass 1 via a rod of length L (forms a 90 degree angel with the first rod, and is otherwise rotatable).[/B]
1. Find the lagrangian
2. Find the equations of motion with the euler-lagrange equations
3. Find the solutions to the equations of motions
L = T-V
[tex]\frac{d}{dt} \frac{\partial L}{\partial \dot z} - \frac{\partial L}{\partial z}[/tex]
[tex]\frac{d}{dt} \frac{\partial L}{\partial \dot \varphi} - \frac{\partial L}{\partial \varphi}[/tex]
This is the first time I have to deal with lagrangian mechanics.
I thought we have 2 free coordinates. We have z for the up and down motion and [tex]\varphi[/tex] for the rotation on the x-y Plane of mass 2.
The potential energy is: [tex]V = V_{Spring} + V_{grav1} + V_{grav2} = \frac{1}{2} k z^2 + m_1 g z + m_2 g z[/tex]
The kinetic energy: [tex]T = T_1 + T_2 = \frac{1}{2} m_1 \dot z^2 + \frac{1}{2} m_2 (\dot L^2 + L^2 \dot \varphi ^2 + \dot z^2)[/tex]
[tex]\dot L^2[/tex] must be 0 cause the length of the 2nd rod doesn't change over time
Also I thought, since mass 2 is moving on the edge of a cylinder, I would need to use the kinetic energy in cylinder coordinates for mass 2
Questions:
I plugged my lagrangian into my 2 euler-lagrange equations and got this:
for z : [tex](m_1 + m_2) \ddot z = -kz + (m_1+m_2) g[/tex]
for [tex]\varphi: \frac{d}{dt}(m_2 l^2 \dot \varphi) = 0[/tex]
I am not sure about r. This looks like the equation of motion of a damped harmonic oscillator. It is not clear from the exercise if the spring is damped or not, so I am not sure if that is correct.
The 2nd equation just means, that angular momentum doesn't change with respect to time? Is there anything I could use from the conversation of angular momentum to solve the first equation or am I done here?[/B]
Edit:
Thanks
Hi,
Paumi said:
I am not sure about z. This looks like the equation of motion of a damped harmonic oscillator.
No damping (usually that's a term ##\beta \dot z##). Jus a mass on a spring.
Correct !
Is there anything I could use from the conservation of angular momentum to solve the first equation or am I done here?
There is nothing in common, so: no. The two degrees of freedom are totally independent.
BvU said:
Hi,
Correct ! There is nothing in common, so: no. The two degrees of freedom are totally independent.
Thank you very much! I'll try to solve it now
  • · Replies 26 ·
