Lagrangian Mechanics: Solving for x, y, and z Dot
Gogsey
1). A bead is confined to moving on a wire in the shape of a porabola, given by y=bx^2. Write down the Lagrangian, with x as the generalized coordinate, and the equations of motion for this sytem.
We have L(x, bx^2)
For writing out the Lagrangian as a function of x, I get.:
L = m/2((xdot) + b(xdot0)^2 - mgbx^2
Then we get L = m/2((xdot^2) + 2b(xdot^2) +(b^2)(xdot^4)) - mgbx^2
But when I go to take tthe partial derivatives, everythin for the kinetic energy is in terms of xdot, and that leaves nothing for thetadot, so I'm a little confused.
2). Apply the Lagrangian method for a for a particle moving on a sphere using spherical coordinates.
so so x = rsin(theta)cos(phi), y = rsin(theta)sin(phi), z = rcos(theta)
so L = m/2(x^2 + y^2 + z^2) - U(r)
How do you get xdot, ydot, zdot? I know you just take the derivativebut with respect to what? Phi and Theta, since r is constant?
the "dot" represents a time derivative; you take the derivative with respect to time and apply the chain rule
Yeah that's what I thought, so I get
xdot = rcos(phi)cos(theta)(thetadot) - rsin(theta)sin(phi)(phidot)
ydot = rsin(phi)cos(theta)(thetadot) + rsin(theta)cos(phi)(phidot)
zdot = -rsin(theta)(thetadot)
Then you have to square then and put them into the Lagrangian expressio, which turns out to be a hug mess? It really gets nasty. Any trig identitites I can before squaring each term?
Actually I think I found them.
Applying the dentities I got:
xdot = r(cos(theta + phi)(thetadot + phidot)
ydot = r(sin(theta + phi)(phidot + thetadot)
And z is the same as before.
Ok, so I'm not sure if those time derivatives are correct or not? Do take the derivative of the x, y and z equations with respsct to r, theta and Phi?
Trouble is, when ypu do this then you get a god awful mess, then you have to square them, and now I'm lost.
Please Help
Look at question no. 3 in the PDF.
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
