Laplace Transform Solution for x"+2x'+x=sin(t) x=x'=0
The discussion centers on solving the differential equation x'' + 2x' + x = sin(t) with initial conditions x(0) = 0 and x'(0) = 0 using the Laplace Transform. The participant successfully derived Y(s) = 1/[(s^2 + 1)(s^2 + 2s + 5)] and expanded it into simpler components for inverse transformation. The key formulas for inverse Laplace transformation were identified, specifically the forms for e^(at)cos(bt) and e^(at)sin(bt), which are crucial for deriving the solution.
  • Understanding of differential equations, specifically second-order linear differential equations.
  • Familiarity with Laplace Transform techniques and properties.
  • Knowledge of inverse Laplace Transform formulas.
  • Experience with initial value problems in the context of differential equations.
  • Study the application of the Laplace Transform in solving linear differential equations.
  • Learn about the method of completing the square in the context of Laplace Transforms.
  • Explore the use of Maple software for symbolic computation in differential equations.
  • Investigate the relationship between the Laplace Transform and system response in control theory.
Students and professionals in mathematics, engineering, and physics who are working on differential equations and Laplace Transforms, particularly those seeking to solve initial value problems.
jumpman23bd
Problem: laplace transform of x"+2x'+x=sin(t) x=x'=0
Attempt at problem: I was able to get Y(s)=1/(s^2+1)(s^2+2s+5) and then i expanded it to get [s/10(s^2+2s+5)]-[s/10(s^2+1)]+[1/5(s^2+1)]. The last two terms are easy to transform the first term i completed the square and got 1/10*s/(s+1)^2+4
Question: from maple i know it will be a exp times a sin and cos function of some sort. I don't know how they got that even though i see it in the denominator.
Hi Jumpman,
Firstly, if you did mean to write the DE as x"+2x'+x=sin(t) (with no 5 in front of the x) then you should restart from there. Otherwise, I'll assume you meant x"+2x'+5x=sin(t) with initial conditions x(0)=x'(0)=0.
To find the inverse laplace of [tex]\frac{s}{(s+1)^2+4}[/tex] using the formulae
[tex]\frac{s-a}{(s-a)^2+b^2}\mapsto e^{at}\cos{bt}[/tex]
and
[tex]\frac{b}{(s-a)^2+b^2}\mapsto e^{at}\sin{bt}\, ,[/tex]
begin by rewriting it as
[tex]\frac{s}{(s+1)^2+4} = \frac{s+1}{(s+1)^2+4} - \frac{1}{(s+1)^2+4}[/tex].
Can you proceed from there?
yes I do see it now...thank you
