MHB Find Laplace Transform of $ t^2+1)^2 $ without Expansion
nacho-man
How do you find the laplace transform of this without expanding it?
$ L(t^2+1)^2 $
$ L(t^2+1)^2 $
You can use the fact that for n positive integer is...
$\displaystyle \int_{0}^{\infty} t^{n}\ e^{- s\ t}\ dt = \frac{n!}{s^{n+1}}\ (1)$ ... expanding $\displaystyle (1 + t^{2})^{2}$ in powers of t... Kind regards $\chi$ $\sigma$
I didn't realize immediately that it was requested 'without expanding' ... very sorry!...
$ L(t^2+1)^2 $
The possible solution is the use of a 'forgotten formula' ['forgotten' in the sense that it is neglected from most of the Complex Analysis 'Holybooks'...] according to which if You have two L-transformable functions $f_{1}(t)$ and $f_{2} (t)$ with L-transforms $F_{1} (s)$ and $F_{2} (s)$ and abscissas of convergence $\sigma_{1}$ and $\sigma_{2}$, then the L-transform of the product is given by the integral... $\displaystyle \mathcal {L} \{f_{1}(t)\ f_{2}(t)\} = \frac{1}{2\ \pi\ i}\ \int_{\gamma - i\ \infty}^{\gamma + i\ \infty} F_{1} (z)\ F_{2}(s - z)\ dz\ (1)$
... where $\displaystyle \sigma_{1} < \gamma < \sigma - \sigma_{2},\ \sigma> \sigma_{1} + \sigma_{2}$. In Your case is $\displaystyle f_{1}(t) = f_{2} (t) = 1 + t^{2} \implies F_{1}(s) = F_{2}(s) = \frac{1}{s} + \frac{2}{s^{3}},\ \sigma_{1}=\sigma_{2}=0$. May be it exists a more comfortable way but till now I didnn't succed to find it!(Emo)...Kind regards $\chi$ $\sigma$
$ L(t^2+1)^2 $
To compute this without expanding requires a little trick (especially if you're allowed to do this without using the integral definition of $\mathcal{L}\{f(t)\}$).
Let $f(t) = (t^2+1)^2$. We note that $f(0)=1$.
Thus, $f^{\prime}(t) = 4t(t^2+1)$ and hence $f^{\prime}(0) = 0$.
Finally, we see that $f^{\prime\prime}(t) = 4(t^2+1) + 8t^2 = 12t^2+4$.
Why did we compute all these derivatives? Well, we know that $\mathcal{L}\{f^{\prime\prime}(t)\} = s^2F(s) - sf(0) - f^{\prime}(0)$, which in our case would be $\mathcal{L}\{f^{\prime\prime}(t)\}=s^2F(s)-s$.
Therefore,
\[\mathcal{L}\{12t^2+4\} = \mathcal{L}\{f^{\prime\prime}(t)\} = s^2F(s)-s\]
We now compute the appropriate Laplace transforms and solve for $F(s)$:
\[s^2F(s) - s = \mathcal{L}\{12t^2+4\} = 12\cdot\frac{2!}{s^3}+4\cdot\frac{1}{s}=\frac{24}{s^3}+\frac{4}{s} \implies F(s) = \frac{24}{s^5} + \frac{4}{s^3}+\frac{1}{s}\]
Therefore, $\mathcal{L}\{(t^2+1)^2\} = \dfrac{24}{s^5}+\dfrac{4}{s^3}+\dfrac{1}{s}$.
I hope this makes sense!
Question for the OP. Why would you want to compute this transform without expanding? I mean expanding would be the easiest approach.
BTW - Nice work Chris!
Following Chris's lead, you could keep going
\begin{align}
f(t) &= (t^2+1)^2,\;\;\; &f(0)&=1\\
f'(t) &= 4t(t^2+1)\;\;\; &f'(0)&=0\\
f''(t) &=4(t^2+1) + 8t^2,\;\;\;&f''(0)&=4\\
f'''(t) &= 8t + 16t,\;\;\;&f'''(0)&=0\\
f^{(4)}(t)&=24,\;\;\;&f^{(4)}(0)&=24\\
f^{(5)}(t)& = 0,
\end{align}
Then
$\mathcal{L}\{f^{(5)}(t)\} = s^5F(s) - f(0) s^4 - f'(0) s^3 - f''(0) s^2 - f'''(0) s - f^{(4)}(0) = 0.$
Substitute $f$ and its derivative at zero and solve for $F$ (same answer)
Thanks for the responses.
@Jester, really no other reason than for the sake of it. I've just started to learn laplace transforms and am finding a little out of the box thinking helps a lot.
A sphere as topological manifold can be defined by gluing together the boundary of two disk. Basically one starts assigning each disk the subspace topology from ##\mathbb R^2## and then taking the quotient topology obtained by gluing their boundaries. Starting from the above definition of 2-sphere as topological manifold, shows that it is homeomorphic to the "embedded" sphere understood as subset of ##\mathbb R^3## in the subspace topology.
