Laplace transforms of differential equations
TyErd
I've attached the problem.
L(1) = 1 /s
L(t^n) = n!/s^(n+1)
because the question only asks for X(s) I only considered the x' + x + 4y=3 equation.
I applied laplace tranforms and got:
s X(s) - x(0) + 1/s^2 + 4/s^2 = 3/s. since x(0) = 0 it gets canceled out so..
s X(s) + 5/s^2 = 3/s
s X(s) = 3/s - 5/s^2
therfore
X(s) = (3/s - 5/s^2) / s
only problem is, i didn't use the other equation which makes me feel I've done it wrong.
In
sX(s) - x(0) + \frac{1}{s^2} + \frac{4}{s^2} = \frac{3}{s}
how are you getting
L(1) = 1 /s
L(t^n) = n!/s^(n+1)
therfore
It's well you should feel you've done it wrong.:frown:
You have two equations in two unknowns, x and y. When you transform, each equation will have an X(s) and Y(s). You left out the Y(s). You will get two equations in the unknowns X(s) and Y(s) which you can solve for X(s).
Omg I feel so stupid right now, i can't believe i was trying to laplace transform a x and y variable >.<
so it should be s X(s) - x(0) + X(s) + 4 Y(s) = 3/s and s Y(s) - y(0) + 9 X(s) + Y(s) = 0 simplify and it becomes
s X(s) + X(s) + 4 Y(s) = 3/s and s Y(s)+ 9 X(s) + Y(s) = 0
rearrange the second equation and it gets me Y(s) = -9 X(s) / (s+1)
s X(s) + X(s) - 36 X(s) / s+1 = 3/s
X(s) [s+1- 36/(s+1) ] = 3/s
X(s) = 3(s+1) / x(s^2 + 2s - 35)
not sure if calculations are correct.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
