Which Laptop Charger is More Efficient for a 65W Rated Laptop?
  • Thread starter Thread starter selseg
    Charger Laptop
When comparing laptop chargers rated at 19V 2.64A and 19V 3.42A for a 65W laptop, the higher-rated charger is generally more efficient and safer. Using a charger with a lower current rating may lead to potential overheating or failure, especially if the laptop draws more current than the charger can handle. It's important to select a charger that matches the laptop's power requirements to avoid damage. Li-ion batteries require a constant current for charging, and using an intelligent charger can optimize battery health. Ultimately, the charger must be suitable for both powering the laptop and charging its battery effectively.
selseg
A laptop charger rated 19V 2.64A and another rated 19V 3.42A what advantages would one have over the other.If I am using it for a laptop rated 65W
One will work, one won't, or will catch fire
65W is 19V at 3.4A
Potentially the 50W charger could be ruined. Your lap top may well be drawing more current then the rated power of the charger. It may work fine for short periods of time, but then it could also fail. Generally it is not a good idea to run power supplies at higher then rated currents.
You need the one which is suitable for the battery. Hard to say which one that would be. Depends on their characteristics . I thought Li-ion required constant current charging and the charger will produce that current and no more. The larger one will be faster. Depends on how good the lap top charge indicator is and I gather they are rather poor. I would have thought the best way to charge a Li-ion battery is externally with an good quality 'intelligent' charger with a timer.
The lap top power rating has no connection really with the charger rating.
The OP says laptop charger they probably mean the external power supply that runs the machine AND charges the battery rather than just a constant current battery charger.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
