Laptop vs Desktop power consumption
The discussion revolves around the power consumption of laptops compared to desktops, focusing on their efficiency and cost implications for electricity bills. Participants explore various scenarios, including using laptops as desktop replacements and the impact of different hardware specifications on power usage.
  • Some participants suggest that laptops generally consume less power than desktops, with estimates of 90W for laptops and 250W for desktops.
  • Others argue that the actual power consumption can vary significantly based on the specific hardware and usage conditions, with some laptops potentially using less than their rated power.
  • A participant mentions that a laptop's power supply rating does not reflect its average usage, proposing that their laptop averages around 20-25W during use.
  • There is a discussion about the benefits of portability, with one participant noting that using a laptop allows for plugging into different power sources, potentially reducing costs.
  • Some participants raise concerns about whether the power savings from using a laptop would offset the initial cost difference compared to a more powerful desktop.
  • One participant provides a detailed calculation of potential savings based on their local electricity rates and usage patterns, suggesting that the savings could be significant over time.
  • Another participant emphasizes that when comparing power usage, one should consider the total system, including monitors and peripherals, rather than just the desktop unit.
Participants express differing views on the efficiency and cost-effectiveness of laptops versus desktops, with no consensus reached on which option is definitively better in terms of power consumption and overall cost.
Some discussions involve assumptions about average power usage that may not account for specific configurations or usage patterns. There are also references to external links for further information, but these do not provide a complete picture of laptop power consumption.
phenom01
Would buying a laptop save me a lot more money on my electricity bill than a desktop?
Computer science news on Phys.org
Welcome to PF, Phenom.
The simple answer is yes, but not necessarily for the reason that you're thinking of. To figure out relative cost, just look up the wattage of your unit on the power supply or OS. A laptop is probably, but not necessarily, more efficient. The main reason that a portable is cheaper is that you can plug it into someone else's mains. For instance, when I take mine to the bar, I always snag a table next to the pillar with the electrical outlet on it.
so let's say if I am going to be using the laptop as a desktop replacement. Then that means it would use the same power as a desktop? I know that if a PSU saids it is 600W it doesn't mean it uses 600W all the time. It means that's the max it can output. I try to do some research and the average Desktop uses about 250W of power while a laptop uses 90w.
You take you Laptop to the bar? :bugeye: lol
Is it a great strategy to pick up?
Ask yourself if the power savings is enough to offset the money saved by puchasing a cheaper more powerful desktop that you would, generally speaking, be able to use longer and won't have to replace as fast?
That is actually my question. I am in a dilema between a laptop and desktop. My brother has a desktop but he doesn't let me use it. So I am concern if there are two desktop it would increase the electricity bill a lot.
NobodySpecial said:
There is a link in the story: http://www.codinghorror.com/blog/2006/04/how-much-power-does-my-laptop-really-use.html
These are from a few years ago, a tiny new Intel Atom netbook will use a lot less power than a typical 2006 notebook, and a monster overclocked gaming rig may use a lot more than their desktop system.
lets say if we compare a mid range desktop with a mid range laptop with the following specs:
Desktop
CPU: AMD Athlon x3 445
GPU: ATI 5770
MEMORY: 4 GB DDR3 13333
Hard drive: 500 GB SATAII 7200 rpm
LCD: 1900x1600
Laptop
CPU:core i5 540M
GPU: Nvidia Geforce 425M
HDD: 250 GB SATAII 7200 rpm
LCD: 1900x1600 (16:9) HD screen
The desktop is probably about right - the laptop looks a little high. My 15" Dell laptop's psu is rated for 90.1W and since that needs to be enough to charge the battery and run the computer at the same time when necessary, that means the computer probably averages more like 45W.
So you save 205W by running a laptop. I just grabbed my power bill for another thread and I pay $.165 / kWh in southeastern PA. So that's $.0338 / hr. So how many hours a day do you use your laptop? Let's say you're a business and you are thinking about taking away your employees' desktops and giving them laptops (in reality, you'd probably give them monitors and docking stations, but we'll let that go...) so they'll run about 9 hours a day. So that's $1.52 / week or $76 / year (50 weeks of work). If you keep a computer for 5 years, that's $380. So is $380 more or less than the cost difference between the desktop and laptop you'd pick?
[edit] Oh, I forgot that a while back I measured my desktop computer's power usage. I'm a nerd and a gamer and so it has a video card that uses a lot of juice and multiple hard drives... and I still use a 21" CRT. The CPU uses 253W at idle and 416W loaded. The monitor uses 85 W on, 12W in sleep. So if I'm actually gaming, it's about 500W and when I'm not using it, about 265W. But a laptop cannot replace this system.
>21" CRT.
Pick one
I've measured my Dell Inspiron 6000 with a Kill a Watt. While in use it averaged about 20-25 watts. It's worth keeping in mind also that a laptop is all inclusive. You should be comparing it to not just a desktop, but desktop + monitor + speakers.
russ_watters said:
Dale: - What is the rating of the power supply?
Dell 65W AC Adapter Model# PA-1650-05D2
Input: 120 VAC 1.5 Amps
Output: 19.5 VDC 3.34 Amps
It's really weird that they didn't mention this as an
option when I called on the tech support line, don't you think? They almost
tried to dissuade me from taking my laptop into the store.
  • · Replies 24 ·
  • · Replies 104 ·
  • · Replies 18 ·
  • · Replies 16 ·
  • · Replies 17 ·
