What Is the Latent Heat of Ashes?
In summary, when something like paper burns, the ashes that are left behind are primarily composed of carbon, which is a nonmetal that has a low capacity to conduct heat. This may explain why ashes from burned materials, including paper, cool down quickly. Additionally, the concept of latent heat does not apply to the ashes themselves, but rather to the phase transition that occurs during the burning process.
Chucky6
I asked my teacher this but he did not know so he asked me to find out. When you set fire to something (for example paper) then when it burns all of the heat is released, is this the reason why ashes become cold so quickly?
Science news on Phys.org
Ashes are primarily composed of carbon(the result of the chemical reaction that fueled the burning). Carbon, as listed on a periodic table is a nonmetal. A common trend among non-metallic elements is their low capacity to conduct heat. This might explain why the ashes of the spent fuel that was your paper may seem so cool.
What are you talking about?
Latent heat is the heat absorbed or released during a phase transition.But here I see no phase transition,only combustion.
The expression latent heat refers to the amount of energy released or absorbed by a chemical substance during a change of state that occurs without changing its temperature, meaning a phase transition such as the melting of ice or the boiling of water.
I don’t know about Latent Heat of Ashes but I can tell you about Latent heat of Water. May be this could help you.
To calculate the latent heat of condensation in water in the temperature range from −40 °C to 40 °C the following empirical cubic function can be used:
Lwater(T) = − 0.0000614342T3 + 0.00158927T2 − 2.36418T + 2500.79
with a determination coefficient of R2 = 0.999988
Ashes have a lot of surface area, since they consist of lots of small, possibly porous particles. It's not surprising that through natural convection they would cool quickly to ambient temperature.
1. What is latent heat of ashes?
The latent heat of ashes refers to the amount of energy required to convert solid ashes into a liquid state or vice versa, without any change in temperature. It is also known as enthalpy of fusion.
2. How is latent heat of ashes measured?
The latent heat of ashes is typically measured in joules per gram (J/g) or kilojoules per kilogram (kJ/kg) using a calorimeter. This device measures the amount of heat released or absorbed during the phase change of ashes.
3. What factors affect the latent heat of ashes?
The latent heat of ashes can be affected by several factors, including the type of ashes, the temperature at which the phase change occurs, and the amount of energy required to break the bonds between molecules in the solid or liquid state.
4. Why is the latent heat of ashes important?
The latent heat of ashes is important in understanding and predicting the behavior of substances during phase changes. It also plays a role in various industrial processes, such as the production of metals and ceramics.
5. Can the latent heat of ashes be altered?
No, the latent heat of ashes is a physical property of a substance and cannot be altered. However, it can vary depending on the conditions under which the phase change occurs, as well as the composition of the ashes.
  • Thermodynamics
  • Thermodynamics
  • Thermodynamics
9K
  • Thermodynamics
