Is the Conservation of Energy a Law or a Fact?
  • Thread starter Thread starter iantresman
    Facts Laws
The discussion centers on the terminology surrounding the Conservation of Energy, debating why it is termed a "law" rather than a "fact" or "principle." A scientific law describes consistent relationships observed in nature, while a fact is an objective observation. The law of conservation of energy remains valid, even with phenomena like radioactivity, as it highlights the equivalence of mass and energy. The conversation also touches on the limitations of these laws in different contexts, such as general relativity, where energy conservation can be violated. Ultimately, the evolving language in science reflects changes in understanding rather than contradictions in fundamental principles.
iantresman
Although scientists once thought that radioactivity violated the law of conservation of energy, then new understanding of nuclear decay helped demonstrate that the law was fact.
So why do we continue to call the Conservation of Energy a law, and not a fact. Why not a principle? Is there a difference?
From Wiki:
A scientific law is a statement based on repeated experimental observations that describes some aspect of the world. A scientific law always applies under the same conditions, and implies that there is a causal relationship involving its elements.
In the most basic sense, a scientific fact is an objective and verifiable observation, in contrast with a hypothesis or theory, which is intended to explain or interpret facts.
You could say a fact is saying, "Current in this circuit is 10 amps and the voltage is 100 volts". I can observe this by measuring the current and voltage.
In contrast, a law would be saying, "The current through a conductor between two points is directly proportional to the potential difference across the two points". (Which is Ohm's law) There is a relationship between current and voltage that this law describes. The law doesn't describe WHY current is proportional to the potential difference across two points, it only states that it is.
I don't think there's a contradiction between calling the law of conservation of energy a law and calling it a fact. I suppose that calling it a fact is a way of saying that we are sure it is true. My personal preference would be not to use the word fact in this way, but to reserve it to describe individual states of affairs in the universe, such as my living in England, or my cat being tabby.
But if radioactivity can do work then it doesn't violate the law of conservation of energy at all. All it means is that the avenues through with which work can be done were originally incomplete.
Claude.
Once you recognise the equivalence of mass and energy, the conservation law works. But you have to remember that it's only in case of nuclear (very high energy) interactions that the classical law is violated.
Ohm's Law also has a certain range over which it applies and so does Newton's Law of gravitation. No one should loose any sleep over the changing meanings and uses of these names. The big step was taken a long time ago when the word Law ceased to mean a Law, laid down by (a) God and became a description of behaviour of a system. Words are constantly changing their meaning, aren't they? (Wicked!)
The energy-conservation law holds within the realm of special relativity (and also of Newtonian mechanics), because it directly follows from the symmetry of physics under time translations (via Noether's theorem).
It does not hold within general relativity, where energy conservation is violated for non-stationary a non-stationary metrics. E.g., in the Cosmological Standard model space-time on the large scale is described as a Friedmann-Lemaitre-Robertson-Walker metric with an expanding scale factor, which leads to the redshift of photons that travel in free space. This means the photon's energy is not conserved due to the expansion of the scale factor in the metric.
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
Thread 'Recovering Hamilton's Equations from Poisson brackets'
The issue : Let me start by copying and pasting the relevant passage from the text, thanks to modern day methods of computing. The trouble is, in equation (4.79), it completely ignores the partial derivative of ##q_i## with respect to time, i.e. it puts ##\partial q_i/\partial t=0##. But ##q_i## is a dynamical variable of ##t##, or ##q_i(t)##. In the derivation of Hamilton's equations from the Hamiltonian, viz. ##H = p_i \dot q_i-L##, nowhere did we assume that ##\partial q_i/\partial...
