How Does the Lax-Milgram Theorem Utilize Continuity and Coercivity?
  • Thread starter Thread starter muzialis
    Proof Theorem
muzialis
Hi All,
I am going through the proof of Lax-Milgram's theorem.
A lemma states, "H is a Hilbert space, let a(.,.) be a symmetric bilinear form, continuous on H and coercive on W, subset of H. then, {W, a(.,.)} is a Hilbert Space".
This is proved as follows:
Being a(.,.) coercive, it is also an inner product for W.
Let us define $$\parallel \cdot \parallel_{E} = \sqrt{a(w,w}$$ and take a Cauchy sequence $$w_n$$.
This will also be a Cauchy sequence in H because coercitivity implies $$ a (w,w) \geq \alpha \parallel w \parallel ^{2} _{H}$$.
H is a Hilbert space, then complete, so $$w_n \to w$$, with $$w \in H$$.
Since W is closed in H, $$w \in W$$.
Hence, $${ W, \parallel \cdot \parallel_{E} }$$ is complete.
What use is mad then of the continuity assumption?
Thanks
So you took a Cauchy sequence for ##\|~\|_E##. You showed that it is convergent for the norm ##\|~\|_H## and that the limit is in ##W##. But you still need to show that the convergence is also for the norm ##\|~\|_E##.
Micromass,
your point is of course valid. Thank you very much for the help, as usual.
A sphere as topological manifold can be defined by gluing together the boundary of two disk. Basically one starts assigning each disk the subspace topology from ##\mathbb R^2## and then taking the quotient topology obtained by gluing their boundaries. Starting from the above definition of 2-sphere as topological manifold, shows that it is homeomorphic to the "embedded" sphere understood as subset of ##\mathbb R^3## in the subspace topology.
11K
10K
11K
