Find the Lead Pursuit Line to Reach a Planet
  • Thread starter Thread starter GrantB
    Lead Line
To reach a planet moving in a circular orbit while traveling in a straight line, one must determine the lead pursuit line based on the planet's constant angular velocity and their own constant speed. The discussion highlights the confusion around the initial conditions of movement, clarifying that the focus is on intercepting the planet rather than moving away from it. Insights from basic fighter maneuvers and missile guidance trajectories can be applied to solve this problem. The use of mathematical models and engagement geometry is suggested to derive effective guidance laws for interception. Understanding these principles is essential for calculating the correct trajectory to reach the moving planet.
GrantB
Suppose you are at a point (x0,y0) in space. There is a planet at position (x1,y1) orbiting in a circle a distance r away from the orbit center (x2,y2).
The planet has constant angular velocity as it orbits. You move at a constant speed towards the planet, and want to move in a straight line.
How do you determine how to reach the planet, traveling only in a straight line?
Thanks.
Astronomy news on Phys.org
GrantB, when you say "You move at a constant velocity from the planet,..." does that mean you are moving AWAY from the planet? Then you want to determine how to reach the planet, so I am confused.
So, I am guessing you may get some insight on the problem by considering this:
"Basic fighter maneuvers (BFM) are tactical movements performed by fighter aircraft during air combat maneuvering (also called ACM, or dogfighting), in order to gain a positional advantage over the opponent."
http://en.wikipedia.org/wiki/Basic_fighter_maneuvers
This article includes the Lead Persuit attack course, which you mention in the thread title, but do not mention in the post itself.
Sorry, it was a mistype.
It should say:
So, you want to get to the planet, and you are at an arbitrary point a distance d from the planet, moving only in a straight line.
Thanks, and sorry for the mistype.
I think your problem of intercepting a moving planet can be solved by using the methods of missile guidance trajectories. Here is an article you may be able to use. See:
www.jhuapl.edu/techdigest/TD/td2901/Palumbo_Homing.pdf
“Figure 2. Planar engagement geometry. The planar intercept problem is illustrated along with most of the angular and Cartesian quantities necessary to derive modern guidance laws.”
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
3I/ATLAS, also known as C/2025 N1 (ATLAS) and formerly designated as A11pl3Z, is an iinterstellar comet. It was discovered by the Asteroid Terrestrial-impact Last Alert System (ATLAS) station at Río Hurtado, Chile on 1 July 2025. Note: it was mentioned (as A11pl3Z) by DaveE in a new member's introductory thread. https://www.physicsforums.com/threads/brian-cox-lead-me-here.1081670/post-7274146 https://earthsky.org/space/new-interstellar-object-candidate-heading-toward-the-sun-a11pl3z/ One...
