What is the effect of adding ore to a coasting ore cart on its kinetic energy?
Adding ore to a coasting ore cart increases its mass, which affects its kinetic energy. The kinetic energy of the cart remains constant if the speed decreases proportionally to the increase in mass, as expressed in the equation KE = 1/2 mv^2. The discussion highlights that while kinetic energy is not conserved in this scenario, momentum is conserved due to the inelastic collision of the ore with the cart. The ore has no initial horizontal momentum, but as it falls into the cart, the total mass increases, necessitating a decrease in velocity to maintain constant momentum. This illustrates the relationship between mass, velocity, and kinetic energy in a dynamic system.
AJKing
An empty ore cart coasts at a constant horizontal speed under an ore chute. Ore falls vertically into the car. What effect does the addition of the ore have on the kinetic energy of the loaded car?
KE = \frac{1}{2}mv_{o}^2 - \frac{1}{2}mv^2
The solution given:
It is the same as the kinetic energy of the unloaded cart.
I don't understand this. Shouldn't the added ore increase the carts mass, thus altering its Kinetic Energy?
Not to mention the fact that dropping a mass onto a moving object would surely increase its frictional force, altering its velocity.
Am I misunderstanding something? Is this an isolated scenario and the question is just hiding that from me?
I think I understand now.
Let me know if this is wrong:
KE = \frac{1}{2}m_{o}v_{o}^2 = \frac{1}{2}mv^2
Thus, because the mass increases, the velocity must decrease equally if we only consider kinetic energy as a factor in this situation.
But why isn't momentum conserved?
The ore falling vertically into the cart initially has no horizontal momentum. But each bit of mass of the ore is effectively undergoing an inelastic collision with the cart and its then current contents.
Kinetic energy is not conserved in an inelastic collision. But momentum is. The total mass M is increasing. What must be happening to V in order to keep M*V constant?
