Exploring Length Contraction and Light Rays in Frame O: Analysis and Discrepancy
In summary, the length contraction of a rod at rest in frame O' is measured as 2l/γ by observer O who is moving at speed u along the x axis. At t=0, observer O sees light rays from the two ends of the rod coming in at angles that lead to an apparent length of 2lγ. This discrepancy can be explained by the light rays being sent at the same time in the rod system, but at different times in the observer's system, resulting in a perceived distance of 2lγ. Additionally, transforming the vector 2*l x+0 t from the rod system to the observer system also results in a perceived length of 2lγ.
ijustlost
A rod of length 2l is at rest in frame O' with co-ords (x',y',z')=(±l,λ,0)
Observer O moves at speed u along the x axis.
The first part of the question is just to derive the length contraction - fine, O measures the length as 2l / γ
The next part has me stuck:
"Show that, at t = 0, the observer O sees the light rays from the two ends of the rod
coming in at angles that lead to an apparent length of 2lγ (making the assumption
that the rod is oriented parallel to the x-axis with a y separation of λ from the origin).
Comment briefly on the discrepancy between the two results. "
I've tried drawing space-time diagrams, and just got in a bit of a mess. I can work out equations for the worldlines of the front and back of the pole (e.g. for one end (ct,x,y,z) = (ct'γ - lγ u/c, γ t'-lγ ,λ,0) etc), but setting t=0 for front and back just gives the 2l / γ. result
The light rays are sent in the same time at the rod system or in the same time at the observer's system. In the first case, the ray sent from the beginning of the rod will be advanced in time gamma*l*u^2 seconds and the ray sent from the end will be delayed the same quantity.
The result will be that it looks like the rays have been sent from a distance that looks (gamma*l). You can also transform the vector 2*l x+0 t from the Rod system to the observer system, it will become 2*l*gamma.
Related to Exploring Length Contraction and Light Rays in Frame O: Analysis and Discrepancy
1. What is length contraction?
Length contraction is a phenomenon in special relativity where the length of an object appears to decrease when it is moving at high speeds relative to an observer. This is due to the distortion of space and time at high speeds.
2. How does length contraction occur?
Length contraction occurs because of the principle of relativity, which states that the laws of physics are the same for all observers regardless of their relative motion. When an object is moving at high speeds, its length appears to decrease to an observer because time is moving slower for the object in motion.
3. Does length contraction only occur in one direction?
No, length contraction occurs in the direction of motion relative to the observer. This means that if an object is moving horizontally, its length will appear to contract horizontally to an observer. However, the length will not appear to contract if the movement is perpendicular to the observer's line of sight.
4. Is length contraction a real physical phenomenon?
Yes, length contraction is a real physical phenomenon that has been proven through numerous experiments and is an integral part of the theory of special relativity. Without considering length contraction, many phenomena in the universe, such as the behavior of particles at high speeds, cannot be explained.
5. Can length contraction be observed in daily life?
No, length contraction can only be observed at very high speeds, close to the speed of light. At everyday speeds, the effects of length contraction are too small to be noticed. However, it can be observed in particle accelerators and in the behavior of cosmic rays in the Earth's atmosphere.
  • General Discussion
