Why Is My Calculation of Lens Object Distance Incorrect?
The discussion revolves around calculating the object distance from a lens given that a real, inverted image is formed. An object is placed to the left of the lens, resulting in an image to the right that is half the size of the object, with a total distance of 102 cm between them. The formula used, m = -di/do, initially led to confusion regarding the signs and values for distances. The correct interpretation of the terms clarified the calculation, leading to a better understanding of the relationship between object distance and image distance. Ultimately, the participant resolved their misunderstanding and successfully applied the concepts to the problem.
luap12
1.An object is placed to the left of a lens, and a real image is formed to the right of the lens. The image is inverted relative to the object and is one-half the size of the object. The distance between the object and the image is 102.0 cm.
(a1) How far from the lens is the object?
2.m=-(di/do)
3. with the equation above I thought it was just -1/2=120/do and solving for do gives -204 cm, but this answer is wrong, and so is 204. I know that m is negative because the image is inverted. Not sure if my logic is right or not, we haven't covered this yet in class but it is still on the homework.
M = -q/p, in which q is the distance from the lens to the image and p is the distance from the lens to the object. The 102cm given is the distance between the object and image.
That worked, thanks. I had the wrong idea of what the terms actually meant.
TL;DR Summary: Find Electric field due to charges between 2 parallel infinite planes using Gauss law at any point Here's the diagram. We have a uniform p (rho) density of charges between 2 infinite planes in the cartesian coordinates system. I used a cube of thickness a that spans from z=-a/2 to z=a/2 as a Gaussian surface, each side of the cube has area A. I know that the field depends only on z since there is translational invariance in x and y directions because the planes are...
