Leq = (L1*L2-M^2)/(L1*L2-M^2)Hope this helps
The discussion revolves around the analysis of a circuit with two inductors connected in parallel and the application of Kirchhoff’s voltage law. Participants derive the current ratio I1/I2 in terms of the inductances L1 and L2, finding I1/I2 = (L2-M)/(L1-M). They also confirm that the equivalent inductance Leq can be expressed as Leq = (L1*L2-M^2)/(L1+L2-2*M). A capacitor is introduced, leading to calculations for the required inductance L when the circuit operates at a frequency of 1 MHz, with participants arriving at values around 33.33 μH. The conversation emphasizes the importance of understanding the relationships between inductance, mutual inductance, and circuit behavior at resonance.
his_tonyness
FIGURE 4(a) shows two inductances connected in parallel across an a.c. supply.
(a) Apply Kirchhoff’s voltage law to loop abef and to loop abcdef of the circuit.
(b) Hence or otherwise obtain the current ratio I1/I2 in terms of the circuit inductances.
(c) See if you can show that L1 and L2 can be replaced by the
equivalent inductor, Leq, of FIGURE 4(b) where Leq = (L1*L2-M^2)/(L1+L2-2*M)
(d) A 1 nF capacitor is placed across the two inductors (FIGURE 4 (c)). If L1 = L2 = L and k = 0.5, determine the required value of L if the minimum current I flows from the supply when it is at a frequency of 1 MHz.
(a) ABEF : V=jw*L1*I1+jw*M*I2, ABCDEF : V=jw*L2*I2+jw*M*I1
(b) I1= (V*(L2-M)) / (jw*(L1*L2-M^2)) , I2=(V*(L1-M)) / (jw*(L1*L2-M^2))
I1/I2= (((V*(L2-M)) / (jw*(L1*L2-M^2))) / (((V*(L1-M)) / (jw*(L1*L2-M^2)))
I1/I2 =L2-M / L1-M
(c) Leq = I1+I2 , = (((V*(L2-M)) / (jw*(L1*L2-M^2))) + (((V*(L1-M)) / (jw*(L1*L2-M^2)))
=(V*(L1+L2-2M))/(jw*(L1*L2-M^2)) = V/jw*Leq, Leq = (L1*L2-M^2)/(L1+L2-2*M)
(d) Xc= 1/(2*pi*f*C) = j159.155 ohms
The bit I'm stuck on is whether I can solve for L using :
However this is for resonant frequency. A push in the right direction anyone on any of these questions. Can someone explain the origin of why in (c) I1+I2= V/jw*Leq
I1/I2 =L2-M / L1-M
That should be ##I = I_1 + I_2##, the sum of the currents. Current and inductance are completely different animals.
The inductor and capacitor are in parallel, so it would make sense to view this load as parallel admittances. No current will flow if the total admittance is zero, right? How do admittances in parallel combine? You should be able to easily show that the total admittance is zero at resonance.
In general the steady state current through an inductance L due to applied potential V is ##I = V/jωL##. In this problem I1 + I2 is the current total ##I## for the load, and V is the potential across the load. So knowing V and I you can determine an equivalent inductance for the load provided that the current has the same form.
Yt=Y+Y+Y...
wC=j0.006 , Yt=0 , 0= 1/jwL -j0.006, 1/jwL= j0.006 , hence zero admittance
Since current is at a minimum at zero admittance, I can solve for 1 of the inductors since L1=L2=L
1/(2*π*√(L*1*10^-9))=1000000 , L=25.33uH
Admittance is the reciprocal of impedance. Both are complex values. Don't confuse them with their magnitudes (the square root of the sum of the squares of their real and imaginary components).
So for the inductor and capacitor in parallel the total admittance is:
$$Y = \frac{1}{jωL_{eq}} + jωC$$
You're given values for C and ω, so it's a snap to find Leq if Y is zero.
With the net inductance Leq in hand, what's your plan to find the actual inductor value L (where there are two inductors couple by mutual inductance)?
jwC= j0.0063
=25uH
1/Lt=1/L1+1/L2...
I can't find or think of an equation to extract the value of one inductor, the net inductance can't be halved can it.
Well, the problem states that L1 = L2. So replace them with a single variable.
Leq = L1 and L2, but L1=L2, so one inductor is = leq/2 which is 25/1= 12.5uH
No, Leq is the inductance value in parallel with the capacitor that you found for minimum current (resonance). You also found an expression for the equivalent inductance for the two mutually coupled inductors. You want to find the values for those two coupled inductors. The problem states that they have the same value, so simplify the equivalent inductance expression accordingly. Use the expression for mutual inductance with the coupling constant k, too.
Ok, simplifying the Lt/Leq equation to one inductor variable I get Lt = (L^2-M^2)/(2L-2M), With mutual inductance equation,simplifying, M= k*L
combining the mutual inductance equation with the Leq/Lt equation (i.e Replacing M in Lt equation with k*L)
I get L = 33.33uH
I get L = 33.33uH
That looks about right. I'm seeing a slightly higher value, but that could be down to rounding of intermediate values.
Re-calculated with Lt= 25.33*10^6 , I get 33.77uH
Okay, now we agree :)
Wonderful, thanks for your help again. :)
Hi
I don't quite follow question (b), any pointers would be appreciated.
Regards
Electest said:
Hi
Regards
What isn't you don't follow? Can you show what you've tried / thought about?
Hi gneill
Thanks for the swift reply
Part (a) was straight forward, but part (b) I'm not following, as this is not mentioned in any of my study material. I have looked through various books, but am a little stumped. Can't quite understand what they are asking.
Regards
They want you find an expression for I1/I2, presumably starting with the loop equations that you obtained in part (a).
Hint: Start with the loop equations in the form: V = <stuff>.
Thanks Gneill
I'll have a look into that and get back to you
Regards
Hi Gneill
Not quite sure why I'm struggling with this, but I am. :nb)
I have 2 KVL loops
ABEF V = jwL1I1 + jwMI2
ABCDEF V = jwL2I2 + jwMI1
Which I guess I'm looking at solving for both I1 and I2 using simultaneous equations, either by substitution or elimination. But I cannot find a solution. Can you please point me in the right direction as I want to fully understand this.
Regards
You're looking for a ratio of the two unknowns I1 and I2, so you really don't need to solve for particular values of them. Just equate the two (V = V, right?) and simplify. Show your work.
So
jwL1I1 + jwMI2 = jwL2I2 + jwMI1
Solve for I1/I2
I'll get cracking and post my result
Hi Gneill
I'm not getting anywhere fast with this and wondered if I'm looking at this wrong. I have been trying to make I1 and I2 the subject (from the equation in my previous post), but it's not working out. What am I missing?
Thanks in advance
Do the usual algebra stuff: Cancel common factors, collect like terms. Put the I1 terms on the left, the I2 terms on the right...
Hi Gneill
I think I was looking at this wrong and over analysing it. I think the initial answer to this (in the beginning of the thread) threw me off.
My result.
I1(L1-M)=I2(L2-M)
I1/I2=L2-M/L1-M
Thanks
Hello,
I am struggling with part d) of the same question. So far I have worked out the L=1/(2πƒ)2C = 25.33μH Which I think is the total value of inductance. To find the value of Mutual inductance I simplified M=k√(L1+L2) to M=kL as L=L1=L2. This gave me M=1.2665×10-5.
Then I thought to find the the Leq to use the formula of the previous question Leq=L1L2-M2/L1+L2-2M. I have also seen that when two inductances have the same value Leq=L-M/2. Solving this I get 18.99μF.
I think I'm missing something and I'm not sure what! Any pointing in the right direction would be greatly appreciated.
Barnatron said:
Hello,
Okay.
This "L" is not the same as your "L" above. You should probably give them different variable names. You don't have enough information to find a value for M at this point. For that you need to find the actual values of the two inductors that will be used.
Simplify the Leq equation using the given information about L1, L2, and k (k simplifies too!). You should find a simple relationship between the value of the net inductance Leq and the value of the actual inductors.
You're mixing up the required equivalent inductance and the actual inductances in your attempt. You found the required equivalent value just fine using the resonant frequency and the value of C. Now you need to find what value of L = L1 = L2 will result in that equivalent inductance.
I got it. Thank you very much for the help!
Sorry to drag up old posts, but I am having real trouble with obtaining I1 and I2 from question b).
Can somebody give me a clue as to how I1 and I2 were obtained here? I assume it is something to do with the two voltage loops that were obtained in a), but I just can't seem to balance the algebra. I have a feeling its so basic I will kick myself. Any help will be appreciated, really struggling here!
two loop equations, two unknowns, therefore you need to solve them simultaneously. Use Wolfram Alpha to check your I1 and I2 equations.
Thanks for quick reply, I tried this earlier with no luck... maybe its how I am inputting it into wolfram, I am not sure. I input :
a*b*c+a*d*e=v, a*f*e+a*d*c=v
All I get is a bunch of zero solutions.
  • #31
I am suffering on (c).
I need to find I which is I1+I2
Therefore I need to find I1 and I2
From (b) working backwards by one step.
i1 (L1-m) = i2(L2-m)
Therefore:
i1 = (i2 (L2-m))/ (L1-m)
i2 = (i1 (L1-m))/ (L2-m)
Adding them together I still have two values for I
If I use substitution
I end up with.
i1(L1-m)(L2-m) = i1 (L1-m)(L2-m)
Which I is true, but not at all helpful!
How on Earth do I start this question!
  • #32
For (b) use the two equations you obtained in (a).
Quoting the legend that is gneill. V=V right?
  • #33
Ok so far I have a few values, I have tried following some of the earlier instructions but I'm stuck for part (d)
As everyone L=1/((2pif)^2)C
L=25.33 microhenrys
M=k sqrt L1L2
Or M=kL
K=0.5
M=0.5L
With rearranging
Leq = (L^2 - m^2)/(2L -2m)
Replace m with kL
Leq=(L^2-0.5L^2)/(2L-(2x0.5L)
Leq=(L^2-0.5L^2)/L
Leq=(L-0.5L)
Leq=0.5L
Leq=25.33 microhenrys
25.33 microhenrys = 0.5L
L=50.66 micro-henrys
is this right or have I done it wrong?
  • #34
Yeah I have tried using the equations from a), but am struggling with solving them simultaneously.
V=jw*L1*I1+jw*M*I2
V=jw*L2*I2+jw*M*I1
I have input it into my calculator to solve for I1 and I2 and get the correct answers. I can't get the same answer in Wolfram. I would really like to know how to solve these two for I1 and I2 without using my calculator. Any more help would be hugely appreciated. Maybe just the first step to solving, to get the ball rolling?
L=25.33 microhenrys
M=k sqrt L1L2
Or M=kL
K=0.5
M=0.5L
With rearranging
Replace m with kL
Leq=(L^2-0.5L^2)/L
Leq=(L-0.5L)
Leq=0.5L
I don't think that's the correct answer, I think its around 33. I have it worked out at home on paper, I will have to check tomorrow unless somebody else beats me to it.
Thanks
  • #35
M=0.5L
With rearranging
Replace m with kL
M is 0.5L, but you've replaced M2 with 0.5 L2. The 0.5 should not have escaped the squaring!
  • #36
V=jw*L1*I1+jw*M*I2
V=jw*L2*I2+jw*M*I1
This is basic simultaneous equations.
Rearrange the first equation so you have I1 = <stuff>.
Substitute that <stuff> into the second equation where I1 appears. Solve for I2. Use this result to replace I2 in the <stuff> in order to obtain a value for I1.
Likes earthloop
  • #37
I knew it would be something ridiculously simple. Thank you very much gneill. I'm laughing at myself at the moment.
  • #38
V=jw*L1*I1+jw*M*I2
V=jw*L2*I2+jw*M*I1
Thanks
I don't know if you've solved it yet, but if you haven't here's some help. Write both of your equations down, then write down v=v underneath and see what you you spot about these three equations. Can you do some substitution?
Then simply follow through using basic algebra.
Likes earthloop
  • #39
Thanks gneill and the-daddy. Really appreciate the help.
  • #40
I1/I2 =L2-M / L1-M
Assuming we're looking at the same course notes - please can you tell me where in the notes you have got the above from? I can't see anything like that in the notes - lesson 12 pg35 has something similar but it's less than half a page and is only the bottom half of the equation.
  • #41
And then i saw page 2 of this thread and arrived at the answer.
  • #42
I1/I2 =L2-M / L1-M
Tony (or anyone else),
Can you tell me why, when answering part (b) you did this I1= (V*(L2-M)) / (jw*(L1*L2-M^2)) , I2=(V*(L1-M)) / (jw*(L1*L2-M^2))?
I answered (b) fairly easily using the equations from part (a), namely V = jωL1I1 + jωMI2 & V = jωL2I2 + jωMI1
jωL1I1 + jωMI2 = jωL2I2 + jωMI1
simplified down to
I1 / I2 = (L2-M) / (L1-M)
which is the same answer that you got. I'm just curious as to why you decided to jump into it the way you did, as i can see nothing in the course notes that would have made me come at it the way you did. But then the way you came at it made made part (c) easier - a part I'm now struggling to answer.
Thanks,
  • #43
Hi Gremlin,
I don't think Tony "jumped" into that answer for I1, I certainly didn't, and if he did I'm curious too! o_O
Have you actually tried expressing your answers from a) (v=...) as their currents I1 and I2? And then substituting them back into the answers from a)?
Have a go at it and show some working out and let me know if you need any help!
EL
  • #44
I1/I2 =L2-M / L1-M
For (a) isn't V supposed to become negative when it goes to the other side of the equal sign. Or what am I missing?
  • #45
I am not sure what you mean, show what you have worked out and I can help.
  • #46
I don't really want to make a new thread for this as it probably doesn't warrant it, but in my textbook i have the equation:
I2rms R= { (I sin (ωt))2 R}avg
The I in the brackets has a little cresent or semi circle above it - does anyone know what this denotes?
  • #47
Got this question sorted, thanks anyway.
  • #48
Hi all,
I am really struggling with part c of this question and have been stuck for a while, i would really appreciate any help.
I think i have the strategy worked out which is:
Use Loop ABEF and re-arrange for I1
Use I1 in Loop ABCDEF to re-arrange for I2
Use I2 in loop ABEF to calculate I1
I then should add I1 and I2 which should give me Leq.
Is this correct?
  • #49
I'm really struggling with part C of this question to, I'm going around in circles can anyone help?
  • #50
You have to show what you've tried. No help without first showing your own efforts, as per the forum rules.
