Leveling mounts for a platform to hold around 300 lbs?
  • Thread starter Thread starter JustinLiang
    Platform
The discussion revolves around the construction of a platform designed to support approximately 300 lbs, specifically addressing the use of leveling mounts for stability and height adjustment. Participants explore the specifications and capacities of different mounts, as well as material recommendations for the platform itself.
  • One participant inquires about the difference in capacity between leveling mounts rated for 300 lbs and those rated for 600 lbs, questioning the rationale for choosing the lower capacity option.
  • Another participant confirms that the mounts are adjustable but notes the minimum height requirement, indicating that the actual height of the table must account for this adjustment.
  • A follow-up question asks whether the 2 1/2" thread length allows for a full 2 1/2" of adjustment or if some length is lost within the mount.
  • There is a suggestion that matching the mount capacity to the load is important if vibration damping is a consideration.
  • A participant seeks recommendations for suitable materials for the platform itself.
Participants generally agree on the adjustable nature of the mounts, but there is no consensus on the necessity of the different capacities or the implications for material choice and vibration damping.
Participants express uncertainty regarding the specific height adjustments and the impact of thread length on the overall height of the platform. There are also unresolved questions about the importance of load capacity in relation to vibration damping.
Individuals interested in constructing platforms for heavy equipment, particularly those concerned with stability, height adjustment, and material selection in engineering or DIY projects.
JustinLiang
I need to build a platform (10 in off the ground) that can hold a fan, air damper and silencer which is in total around 300 lbs of weight. I was looking at these leveling mounts that I could use for the table feet:
I noticed that there is one that says 300 lbs capacity per mount and another one says 600 lbs capacity per mount. They are the same price so why would anyone want to purchase the 300 lb one?
Also, I just want to make sure... You can adjust these right? In case you want to make your table slightly higher?
Cheers
Yes. they adjust. Note that they have a minimum height (C - A) of 13/16". So your actual physical table needs to be 10" - 13/16" = 9 3/16" in height. And you have to accommodate for the additional height of the nut. I do not see that value.
So the 2 1/2" thread length means that you can adjust the table up to 2 1/2"? Or would it be less since some of the thread length is inside the mount.
Also, what material do you guys recommend I use for the actual platform itself?
In fact the ones from 40lb down seem to be the same size and price.
You would want to match capacity to load if vibration damping was important.
  • · Replies 17 ·
