Levitating wire in magnetic field.
To levitate a copper wire in Earth's magnetic field, the current density (J) must be calculated using the formula JVB = density(V)g, indicating that J should flow in the east direction. For part (b), the power dissipated per cubic meter due to resistive heating can be expressed as P = J^2 x resistivity x V, though the specific volume (V) is not provided. The discussion emphasizes the need to derive equations and simplify terms, suggesting that dimensions will cancel out. Participants are encouraged to create unknowns for cross-sectional area and other variables to facilitate calculations. The focus remains on correctly interpreting the homework questions rather than finding numerical values.
SherlockOhms
A copper wire of diameter d carries a current density at the Earth’s equator where the Earth’s magnetic field is horizontal, points north, and has magnitude 5.yz × 10^-5 T . The wire lies in a plane that is parallel to the surface of the Earth and is oriented in the east west direction. The density and resistivity of copper are ρm = 8.9 × 10^3 kg/m3 and ρ = 1.7 × 10^−8 Ω-m, respectively. (x,y and z are given constants).
(a) How large must J be, and which direction must it flow in order to levitate the wire? Use g= 9.81 m/s
.(b) When the wire is floating, how much power will be dissipated per cubic meter due to resistive heating in the wire?
F = ILB (F = JALB = JVB.)
F = mg.
m = density(Volume)
So, F = density(volume)(g)
JVB = density(V)(g)
cancel the V's and solve for J (Positive so it flows in the east direction?)
I think that's the correct way to do (a), please point out if I've made an error. I can't seem to find the relative equation for part (b). Any help would be great!
Anyone have any clue? I can't see a way to do it without some extra numerical value for the dimensions of the wire.
The specific dimensions should cancel out. Create unknowns for cross-sectional area etc. as necessary and post you working.
Well, I said that resistance = (resistivity x L) / A. Then JA = I. Power = (JA)^2 x (restivity x L) / A. This simplifies to be P = J^2 x resistivity x V. I don't know the value of V though. I'm not sure what way you had in mind. Any ideas?
You are not asked to find P. What does the question ask for?
