Solving Equation w/ L'Hopital's Rule When x = 0
  • Thread starter Thread starter Fluidman117
Fluidman117
I have an equation in which a term equals zero and in this case the whole equations equals zero. I know it is possible to use the L'Hopital's rule to calculate the equation but having I'm having a little trouble.
The equation I would like to is the following:
k = \frac{pA}{x}*[(\frac{V}{V-Ax})^y - 1]
I have to solve this when x = 0;
Plugging in 0 for x, results in 0, which should not be the answer. I figure it is possible to use the L'Hopitals rule, but currently only my denominator has the x term which would be approaching zero. But in order to use the rule I would have to manipulate the equation for both the numerator and denominator to approach zero?
Instead of using de L'Hospital's rule you can (equivalently) expand the expression in the square brackets in powers of x. This should help!
But if I would still like to use L'Hopital's rule, how should I proceed?
Differentiate the numerator wrt x
Not true. It results in 0/0 !
Your function is ##f(x)## is of the form
f(x) = \frac{N(x)}{x}, \;\; N(x) = pA\left[ \left(\frac{V}{V-Ax}\right)^y -1\right]
When you use l'Hospital's rule (not l'Hopital!) you compute
\lim_{x \to 0} f(x) = \frac{N'(0)}{1},
so all you are really doing is just taking the first term of the series expansion of ##N(x)##. l'Hospital and series expansion are really the same thing.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
