Calculating Wing Lift with a DIY Scale and Air Supply
A DIY setup using a scale and air supply was created to measure wing lift, resulting in a negative value on the scale due to lift forces. To accurately calculate lift, the wind must be perpendicular to the scale's measurement axis, and any wind affecting the scale must be accounted for. The measurement process requires ensuring parallel wind streamlines for accurate results. Additionally, lift measurements can be influenced by turbulence levels. Understanding these factors is crucial for precise lift calculations.
Ignacio12
Hi!
I have attached a small sheet of wood to a stand and then all of it to a scale. After that with a air supply I've made wind go through the "wing". Due to lift, the scale showed up a negative value. Knowing that value, is it possible to calculate the lift of the wing?
Thank you
How would you define lift? And how does what you are measuring differ from that?
The wind must be perpendicular to the scale's measurement axis, and any wind impinging on the weighing platform must be subtracted out. The trick is getting parallel wind streamlines. Also, lift will vary with the amount of turbulence.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
