Light after a Polarizer Question
  • Thread starter Thread starter iurod
    Light Polarizer
To determine the angle between the axes of two polarizers that allows 37.5% of the initial intensity of unpolarized light (240 W/m²) to pass through, the first polarizer reduces the intensity by half, resulting in 120 W/m². The transmitted intensity after the second polarizer is set to be 0.375 times the initial intensity, leading to a calculation where I2 equals 0.75 times I1. By applying the equation I2 = I1 * cos²(θ), it is found that cos²(θ) equals 0.75, resulting in an angle of 30 degrees. The solution confirms that the calculations are correct and the angle needed is indeed 30 degrees.
iurod
Initially unpolarized light with an intensity of 240W/m2 is incident on a series of two polarizers. What should be the angle between to the axes of the two polarizers such that the transmitted intensity after the second polarizer is 37.5% of the incident one?
I=I0cos2\theta
I1=.5Iocos2\theta (unpolarized light is reduced by halve after the first polarizer)
this can also be written at 2I1=Io
We are given that I2=0.375I1
2I1=Io so I2 really equals 0.75I1
0.75I1 = I1cos2\theta
0.75=cos2\theta
\theta = 30 degrees
Did I do this correctly?
Thanks for all your help...
Looks good!
