Light intensity and photosynthetic rate
The discussion focuses on the relationship between light intensity and photosynthetic rate, emphasizing that as light intensity decreases, oxygen production also declines. It clarifies that light rays do not lose energy with distance; instead, their intensity appears to decrease because they spread over a larger area. The conclusion drawn is that light rays are more concentrated when closer to the plant. Participants inquire about the specifics of the experiment, such as the type of light source and whether the power or location of the light source was altered. Overall, the conversation highlights the importance of understanding how light distribution affects photosynthesis.
Propagandhi
I'm doing a report for biology about the relation betweem light intensity and photosynthetic rate. My results showed that as light intensity decreases, so does oxygen production.
I said in my discussion that light rays that must travel longer distances will lose energy and appear dimmer than rays that travel shorter distances.
Is this correct?
Science news on Phys.org
I'm afraid not.
Light rays don't lose energy with distance. The apparent intensity of a light source does decrease with distance, but that's because the light is spreading out to cover a larger area.
So a more appropriate conclusion would be that the rays are more concentrated when they are closer to the plant?
Can you describe the experiment a little more. What type of light source did you use? What did you actually change ... the power of the light source, or the location of the light source?
Typically, light rays are more concentrated closer to the source of the light. Move the plant away from the source, and the light becomes less concentrated (i.e. dimmer) at the plant.
This assumes you're not using lenses to focus the light, or a laser where the light intensity is fairly constant over a large distance.
Thread 'A quartet of epi-illumination methods'
Well, it took almost 20 years (!!!), but I finally obtained a set of epi-phase microscope objectives (Zeiss). The principles of epi-phase contrast is nearly identical to transillumination phase contrast, but the phase ring is a 1/8 wave retarder rather than a 1/4 wave retarder (because with epi-illumination, the light passes through the ring twice). This method was popular only for a very short period of time before epi-DIC (differential interference contrast) became widely available. So...
I am currently undertaking a research internship where I am modelling the heating of silicon wafers with a 515 nm femtosecond laser. In order to increase the absorption of the laser into the oxide layer on top of the wafer it was suggested we use gold nanoparticles. I was tasked with modelling the optical properties of a 5nm gold nanoparticle, in particular the absorption cross section, using COMSOL Multiphysics. My model seems to be getting correct values for the absorption coefficient and...
