Light travelling through differing mediums
  • Thread starter Thread starter fmdk
    Light
When light travels from water to air at an angle, Snell's Law is essential for determining the angle of refraction. This law states that the ratio of the sines of the angles of incidence and refraction is equal to the ratio of the speeds of light in the two mediums. The refractive indices of the mediums, calculated from the speed of light in each, play a crucial role in this relationship. Key factors to consider include the angle of incidence and the refractive indices of both water and air. Understanding these principles allows for accurate predictions of light behavior at the interface.
fmdk
If light traveling in water hits an interface with air at angle x, what is the angle it will make when traveling in air?
what factors do i need to consider for this apart from:
different lights travel at different speeds
different mediums will affect angle of incidence
The thing you're looking for is probably called "Snell's law" (named after a Dutch scientist with the fancy Latin name Snellius):
\frac{\sin \theta_1}{\sin \theta_2} = \frac{c_1}{c_2} = \frac{n_2}{n_1}
where n_i = c / c_i and c_i is the speed of light in medium i (and c in vacuum).
