Lightning question before the test : )
  • Thread starter Thread starter frasifrasi
    Lightning Test
frasifrasi
How can I show that the sequence { 4^(n)/n! }
converges to zero (by squeeze theorem)??
Thank you! : )
Thank you! : )
If the Squeeze Theorem is required as part of the proof, how about comparing
\frac{4^{n}}{n!} < \frac{4^{n}}{n^{n}} (for n > 1)
and showing that the latter goes to zero as n--> infinity?
Minor correction, but the "for n > 1" part isn't correct. You can find the correct value, or just say sufficiently large n.
as n->infinity n^n>n! so \frac{4^n}{n!} &gt; \frac{4^{n}}{n^{n}}.
I think probably the idea being expressed was to use a constant in the denominator instead of n. \frac{4^n}{8^n}. (or any constant^n in the denominator where the constant>4)
\frac{4^n}{n!}&lt; \frac{4^n}{8^n} for large enough n.
Whoops! Quite so -- I was only looking at the denominators. That needs to be n > 2 , doesn't it? (n=3 works...)
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
