Starting a Limit Problem with x^3/(tan^3(2x)) as x Approaches 0
  • Thread starter Thread starter gillgill
To evaluate the limit of x^3/(tan^3(2x)) as x approaches 0, start by expressing tan^3(2x) as sin^3(2x)/cos^3(2x). This allows the limit to be rewritten as x^3 * cos^3(2x) / sin^3(2x). Utilizing the limit property that lim (sin(αx)/(αx)) = 1, substitute 2x for α in the limit. The final evaluation involves simplifying the expression to find the limit as x approaches 0, leading to a result that incorporates the behavior of sin(2x) and cos(2x) near zero. This approach effectively resolves the limit problem.
gillgill
How do you start this problem?
lim x^3/(tan^3(2x))
x->0
Use
\tan{x} = \frac{\sin{x}}{\cos{x}}, \; \mbox{and} \ \lim_{x \rightarrow 0} \frac{\sin{\alpha x}}{\alpha x} = 1
how do you split tan^3(2x) into sin and cos?...sin^3(2x)/cos^3(2x) or sin(2x)^3/cos(2x)^3??
1): \ \ \ \ \tan^{3}(2x) \ = \ \frac {\sin^{3}(2x)} {\cos^{3}(2x)}
2): \ \ \ \ \Longrightarrow \ \ \frac {x^{3}} { \tan^{3}(2x)} \ = \ \frac {\cos^{3}(2x)} { \frac {\sin^{3}(2x)} {x^{3}} } \ = \ \frac {\cos^{3}(2x)} { \frac {\sin^{3}(2x)} {(1/8) \cdot (2x)^{3}} } \ = \ \left( \frac{1}{8} \right) \cdot \left ( \frac {\cos^{3}(2x)} { \left ( \frac {\sin(2x)} {(2x)} \right )^{3} } \right )
Now use info provided by Data in MSG #2 to evaluate required Limit.
thanks...^^
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
