Limit for a problem of convergence
  • Thread starter Thread starter gentsagree
    Convergence Limit
gentsagree
I ultimately want to discuss convergence of the integral
\int_{0}^{\infty}\frac{1}{\sqrt{x}e^{\sqrt{x}}}dx[/B]
\int_{c}^{\infty}\frac{dx}{x^{p}}
is convergent near x approaching infinity for p>1
3. The Attempt at a Solution
While I understand that the integral converges near 0, as x->infinity I find, for the integrand
\lim_{x \rightarrow \infty }\frac{1}{\sqrt{x}e^{\sqrt{x}}}=\lim_{x \rightarrow \infty }\frac{1}{\sqrt{x}\left( 1+\sqrt{x} + \frac{x}{2} + \cdots \right) }=\lim_{x \rightarrow \infty }\frac{1}{\left( \sqrt{x} + x + \frac{\sqrt{x}x}{2} + \cdots \right) }
but the solution given to me says that I should end up with
\frac{1}{\left(\frac{\sqrt{x}x}{2} + \cdots \right) }
which converges as p would be always greater than 3/2, but I don't see how the limit gets rid of the first two terms in the denominator.
Thanks!
Thanks!
Much easier: change variables. There is a particularly "obvious" transformation, but if I tell you exactly what it is I will be violating PF rules.
The integral indeed converges because you know the integral below on the right converges:
$$\int_0^{\infty} \frac{1}{\sqrt{x} e^{\sqrt{x}}} \space dx \leq \displaystyle \lim_{a \rightarrow \infty} \int_0^a \frac{1}{e^{\sqrt{x}}} \space dx$$
So to determine what the integral on the left converges to, note that:
$$\sqrt{x} e^{\sqrt{x}} = \sum_{n}^{\infty} \frac{x^{\frac{n+1}{2}}}{n!}$$
So that:
$$\int_0^{\infty} \frac{1}{\sqrt{x} e^{\sqrt{x}}} dx = \int_0^{\infty} \frac{1}{\sum_{n}^{\infty}\frac{x^{\frac{n+1}{2}}}{n!}} dx$$
I don't see how you get that inequality. Is that what you meant?
Anyway, Ray's method is much simpler.
The integral is improper at ##0## and your inquality fails near ##0##.
Yes I don't know what I was doing using series, I wasn't fully awake when I wrote that, sorry. There is a much simpler way that has been mentioned already.
There are two discontinuities here: x = 0 and x = infinity
so rewrite as lim a→0 (lim b→∞ (∫dx/(√x e*√x) from a to b))
u = √x
2du = dx/√x
lim a→0 (lim b→∞ (∫e^-u du from a to b))
= lim a→0 (lim b→∞ -e^-b + e^-a)
= 0 +1
= 1
I don't think it means anything to say there's a discontinuity at infinity. The definition of an integral to infinity is the limit as the range tends to infinity.
ARaslan said:
2du = dx/√x
You later lost the 2.
Yes you are right, it does not make sense to say that there's a discontinuity at infinity. I just meant that we can not treat as a normal limit of integration and we are going to have to take the limit as that limit goes to infinity. Thank you from pointing that out.
And yup, i must gave forgotten to write the two. so the correct answer is 2, not 1. Thanks again.
The solution given to you says you should get something with x in it after taking limits?
If you can find a value for the integral, then you know it converges. Taking the limit of the integrand as x goes to infinity will only tell you whether or not the integrand goes to zero. In this case, it does - however you still don't know if it converges or diverges. You can recognize that the integrand is just the derivative of the function -2e^{-\sqrt{x}} and so you can use the fundamental theorem of calculus (part 2) and then evaluate the limits.
