Limit of function ( sandwich method)
The discussion focuses on using the sandwich method to prove that the limit of sin(n)/n approaches zero as n approaches infinity. Participants clarify that n should be considered a positive integer, which is crucial for applying the inequality -1/n ≤ sin(n)/n ≤ 1/n correctly. Confusion arises from the misinterpretation of n as potentially negative, which is not applicable in this context. The importance of proper notation in LaTeX is also highlighted, particularly the correct representation of infinity. The thread concludes with a resolution of the initial misunderstanding regarding the nature of n in the limit proof.
Дьявол
limit of function ("sandwich" method)
Using the "sandwich" method prove that \lim_{n\rightarrow \propto }(\frac{sin(n)}{n})=0
x_n \leq y_n \leq z_n
\lim_{n\rightarrow \propto }(x_n) \leq \lim_{n\rightarrow \propto }(y_n) \leq \lim_{n\rightarrow \propto }(z_n)
I am honestly little bit confused at this point.
If the answer is:
\frac{-1}{n} \leq \frac{sin(n)}{n} \leq \frac{1}{n}
then my question is if n=-\frac{\pi}{4} then \frac{-1}{-0.785} will be not less or equal to \frac{\sqrt{2}}{2*(-0.785)}, where -0.785=-\frac{\pi}{4}, where \pi \approx 3.14.
Thanks in advance.
Are you sure that n is a real number? Usually n denotes a positive integer in this type of problem.
-1/n\le sin(n)/n\le 1/n for n positive. Obviously, if n is negative, just -1/n\le 1/nis not true! Your use of x\rightarrow \propto is a little confusing. Did you mean \infty? Even if you do not interpret n as necessarily being positive, if n is "going to \infty" eventually, for some finite N, if n> N, n will be postive. And you can always drop any finite number of terms in an infinite sequence without changing the limit.
Thanks for the posts. I see now, it was my mistake if an=sin(n)/n, an is progression where n are positive integer numbers. So if:
-1 \leq sin(n) \leq 1
then divided by n, I'll get:
-1/n \leq sin(n)/n \leq 1/n
Sorry for the symbol, I misspelled it, since I don't cover LaTeX too good at this moment.
Thanks for the help.
For future reference, in LaTex, \infty is "\infty". \propto is "\propto", i.e. "proportional to".
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
