Limit of Sequence: Using Riemann Sum
  • Thread starter Thread starter llursweetiell
    Limit Sequence
4 replies · 2K views
llursweetiell
consider the sequence {an} where an= 1/(n+1) + ...+ 1/2n. find its limit.
the hint given is using riemann sum.
we know that since it is increasing and bounded above by one, the sequence converges. I'm not sure where to go from there, especially to use the riemann sum.
Yes this question basically asks you if you know how Riemann or Darboux sums work. Hint: consider the function f defined by f(x) = 1/(1+x) on [0,1]. Choose the most standard partition of an interval you can think of and find out how this relates to your sum.
I'm thinking that the partition would be P= 0=x0<x1<x2<...,xn=1 with 1/n partitions. Not sure about how this would relate to the sum that I have in the problem?
Yes, that is the right partition if you meant that there are n subintervals each of length 1/n. Now rewrite the original sum as
[tex]\sum_{k = 1}^{n}\frac{1}{n+k} = \sum_{k = 1}^{n}\left(\frac{1}{1+\frac{k}{n}}\right)\cdot\frac{1}{n}.[/tex]
Finally, consider the upper and lower sums.
Here is what I've come up with:
let f(x)=x/(x+1)
let P be the partition {x0, x1, ...xn} where xi=i/n and ti=xi and the mesh is 1/n=xi-xi-1 (i and i-1 are subscripts)
then S(P,f)=SUM: f(ti)(xi-xi-1) = SUM: 1/(n+1) * 1/n, from i=1 to n which is the sequence an.
since S(p,f) converges to the integral of 1/(x+1)dx, from 0 to 1, an converges to this as well. so the limit of an is the value of the integral, which is ln2.
Is that where you were going with it?
