Proving Limit of Sequence: an+1=an/2 + 1/an
  • Thread starter Thread starter Harmony
    Limit Sequence
Harmony
an+1=an/2 + 1/an
Prove that the above sequence converge and find the limit.
I have used Maple 12 to compute up to 10 term, using different initial value of a0. I found that the sequence is approaching square root of two when a0 is positive, and negative of square root of positive when a0 is negative. From the software, I know that the sequence is convergent, but it is rather difficult to find a mathematical proof.
Is it reasonable to say that an approximate to an+1 when n is approaching infinity? If so how can I prove it? Can I substitute both an and an+1 with ainfinity and find the limit?
Thanks in advanced.
If you know that your thus defined sequence (a_n)_{n\geq0} converges to some number c then the sequence (a_{n+1})_{n\geq0} converges to that same number.
Then you can use the continuity of the function x\mapsto \frac{x}{2}+\frac{1}{x} to take the limit of the equation a_n=\frac{a_n}{2}+\frac{1}{a_n} to obtain c=\frac{c}{2}+\frac{1}{c} which has the solution c=\sqrt{2} of course.
So if the sequence is convergent the limit is \sqrt{2}.
But in order to conclude that your sequence converges in the first place you need to work some more. How would you prove in general that a sequence is convergent?
Harmony said:
an+1=an/2 + 1/an
Thanks in advanced.
Well, you shouldn't call it ainfinity. Rather, IF the sequence converges, say to some number A, then, taking limits on both sides of the equation A= A/2+ 1/A. From that, multiplying on both sides by A, A2+ A2/2+ 1 or (1/2)A2= 1 or A2= 2. Assuming that a0> 0 then A= \sqrt{2}.
That is, of course, IF the sequence converges. With that information, we can then use "monotone convergence" to show that it does, in fact, converge.
As a slight (I hope not too far-reaching) expansion on the previous correct ideas:
1. Try to show that the sequence is non-decreasing (i.e. a_{n+1} \ge a_n)
2. Show that the sequence is bounded above (a_n \le M for some
positive number M)
These two steps together will be enough to prove that the sequence converges; you've already seen how to find the limit.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
