Limit Question involving Fibonacci Sequence.
  • Thread starter Thread starter mmmboh
    Limit Sequence
mmmboh
I'm reviewing for my analysis exam, and am having trouble with this question: Let (fn) be the Fibonacci sequence and let xn=fn+1/fn. Given that lim (xn) = L exists, find L.
I believe I know what technique I have to use. I think I have to find two subsequences of (xn), write one in terms of the other, equate them, and since they have the same limit solve for L, but I can't find a subsequence that I can write in terms of the other, I have tried even n, odd n, n2, etc.
Can someone help?
Thanks
Does it help to use the fact that fn+1=fn+fn-1?
Ugh I see. Wow that was easy...and I actually did try using that, for some reason you writing it made me see the answer. Thanks.
Well, what's fn-1/fn in terms of the x sequence?
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
