Limits and Continuous Functions problem
9 replies · 2K views
adillhoff
Define the function at a so as to make it continuous at a.
[tex]f(x)=\frac{4-x}{2-\sqrt{x}}; a = 4[/tex]
[tex]\lim_{x \rightarrow 4} \frac{4-x}{2-\sqrt{x}}[/tex]
I cannot think of how to manipulate the denominator to achieve f(4), so I start by finding the left and right hand limits then applying the informal definition of a limit.
[tex]\lim_{x \rightarrow +4}\frac{4-x}{2-\sqrt{x}} = 4[/tex]
[tex]\lim_{x \rightarrow -4}\frac{4-x}{2-\sqrt{x}} = 4[/tex]
I do not know if this is the right way to solve this problem though. If I use this method, I am still left with a function where f(4) is discontinuous. Any hints would be greatly appreciated.
Use the difference of two squares pattern
[tex]a^2 - b^2 = (a - b)(a + b)[/tex]
where a2 - b2 corresponds to 4 - x. See what happens.
Wow that seems so obvious now. I completely overlooked it. Thank you so much for the help.
Your notation needs a bit of tweaking. What you think you wrote, and what you actually wrote are two different things. Your limits were supposed to be one-sided limits around 4. The second limit, above, was as x approaches -4, which is not in the domain of the square root function.
This is what you should have written:
[tex]\lim_{x \rightarrow 4^+}\frac{4-x}{2-\sqrt{x}} = 4[/tex]
[tex]\lim_{x \rightarrow 4^-}\frac{4-x}{2-\sqrt{x}} = 4[/tex]
Notice that the plus and minus signs appear after 4.
Can you use L'Hospital's rule for something like this? The limit is in the indeterminate form of 0/0 and the result of one iteration of L'Hospital is 2√x which is continuous at x=4... Am I cheating here?
Yes, you could use L'Hopital's rule but that would be "over-kill". eumyang's suggestion is much simpler.
I guess it doesn't seem obvious to me using the difference of squares then... Would you mind writing it out?
Ken
Ken
[tex]4 - x = (2 - \sqrt{x})(2 + \sqrt{x})[/tex]
After that, you get cancellation.
Omg! I was working the pants off the denominator and totally missed that the numerator was the key! Thanks!
Ken
Another, similar, way to do this is to multiply both numerator and denominator by [itex]2+ \sqrt{x}[/itex].
