Mastering Limits: Solving Infinity and Radical Problems with Sin and Cos
  • Thread starter Thread starter EasyStyle4747
    Limits
The discussion focuses on solving limit problems involving infinity and radical expressions, with participants seeking clarity on specific limits. Key problems include finding the limit of x divided by the square root of (x^2 - x) as x approaches negative infinity, and various limits involving sine and cosine functions as x approaches infinity. Participants discuss techniques such as L'Hôpital's rule and the behavior of oscillating functions like sine and cosine, which are bounded between -1 and 1. There is an emphasis on understanding how these properties affect the limits being calculated. Overall, the conversation highlights the challenges and strategies in mastering limits in calculus.
EasyStyle4747
limits help!
ok I am going to try my best to express these problems because I don't really know how to get some of these symbols. If someone knows how to represent these:
infinity
radical
please tell me.
On to the problems (we need to find the limit):
1)
lim x / radical(x^2-x)
x-> -infinity
I basically tried multiplying the denom. to the denom and num to get rid of the radical. But then what?
2) I don't really understand these sin cos things (again find limit).
a)
lim (x-cosx)/x
x-> infinity
b)
lim 1/(2x+sinx)
x-> infinity
c)
lim cos(1/x)
x-> infinity
d)
lim (sin2x)/x
x-> infinity
I don't need all of these to be done, just choose which one u think is the easiest to explain and explain the best u can to me. thank you.
1) How did you do this one?
2) a)You can split the numerator up can't you? \frac{2+3}{8}=\frac{2}{8}+\frac{3}{8}=\frac{5}{8} I know it's a rudamentry example but it shows what I mean. Also aren't sin and cos functions limited to 1 or -1? Do you know hwo to deal with functions that oscillate? Do you know L'Hopitals?
b) Again, sin and cos functions oscillate between -1 to 1. Think about it now, would ±1 have a big effect on (2*infinity)?
c) what is 1/infinity What is the cos of that result?
d) see above.
i dun quite understand what you mean when you say would +-1 have a big effect on (2*infiinity).
Damn. I thought I had the answer to 1, but a second look spotted errors :redface:
You do (1) in exactly the same manner as if both the numerator and denominator were polynomials... the degree of the numerator is 1, and the degree of the denominator is 1 (1/2 * 2), so...
