Limits of Trig Functions: How to Solve Using L'Hopital's Rule?
The discussion revolves around evaluating the limit of the expression (1-cos(14x))/(xsin(18x)) as x approaches 0, which involves the application of L'Hôpital's Rule due to the indeterminate form 0/0.
  • Participants discuss the application of L'Hôpital's Rule multiple times, with some questioning the correctness of factoring out constants in the expressions. There is also an exploration of the calculations leading to different limit results.
The discussion includes attempts to clarify the steps taken in applying L'Hôpital's Rule, with one participant acknowledging a calculation error after receiving feedback. There is a mix of interpretations regarding the factoring process and its impact on the limit evaluation.
Participants are working within the constraints of a limit problem that involves trigonometric functions and are adhering to the rules of L'Hôpital's Rule. The initial indeterminate form prompts the need for careful application of calculus techniques.
DeathWish
lim(x -->0) (1-cos(14x))/(xsin(18x))
None?
The hint tells me to use L'hopital's rule through which I got
lim(x-->0) (sin(14x))/(18xcos(18x)+sin(18x)) (I factored out the 14 in the numerator)
That gave me a 0/0 so I did L'hopital's rule again, through which I got
lim(x-->0) (cos(14x))/(cos(18x)-9xsin(18x)) (I factored out 14/2)
This gives me 98, which is wrong. (As x-->0, the function becomes 1, leaving what I factored out as 98)
I'm not sure what to do here. Help? :(
I think it's the things you are factoring out. I don't think you factor out 14/2 to get the expression you showed at the end. Can you show how you did that? Try showing your expressions without the 'factoring out'.
lim(x-->0) (1-cos14x)/(xsin(18x)), this gives 0/0
L'hopital's
lim(x-->0) (14sin14x)/(sin(18x) + 18x(cos(18x))), Gives 0/0
L'hopital's
lim(x-->0) (196cos(14x))/(36cos(18x)-324xsin(18x)) This gives 49/9 which is right...
Thanks, it seems I just screwed up the calculations. Sorry for the bother
L'hopital's
L'hopital's
You are welcome. No problem.
  • · Replies 23 ·
