Lin Alg - Find the basis and dimension
  • Thread starter Thread starter jinksys
    Basis Dimension
jinksys
Find the basis and dimension of the following homogeneous system:
Code:
A =     |1 0 2| |x1|
        |2 1 3| |x2| = [0,0,0]
        |3 1 2| |x3|
My attempt:
Solving the coefficient matrix for RREF, I get the identify matrix.
So, x1=x2=x3=0 and the only solution is a trivial one.
Does that mean there is no basis(empty basis), or that the basis only contains the zero vector and has dimension zero?
The dimension is equal to the number of vectors in a basis, so if the solution space is zero-dimensional, the basis is empty.
Thanks for the help!
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
