Lindhard RPA Dielectric Function Electron Gas
DrDu
The longitudinal dielectric function of a gas of free electrons (+ homogeneous positive background) is often described in the Lindhard- or Random Phase Approximation (RPA).
The dielectric function depends on both frequency omega and wavevector k. However, it is non-analytic at the point omega=0, k=0. Namely its value depends on how the constant ratio of omega/k is chosen in the limit omega to 0. What is the physics behind this behaviour?
The singular structure comes from the existence of gapless excitations at the Fermi surface. Is this answer too brief/trivial for what you were looking for?
Dear Physics Monkey,
Too brief yes, too trivial no. I was thinking the following: when taking the limit omega to 0 before k to 0 (static screening) the electrons have all the time of the world to adjust to the field. In the other limit ( k to 0 before omega to 0) they would have to move with too high velocity over too large a distance.
I also think that the latter limit changes drastically if scattering/band structure is to be included.
This is also the basic picture I have. In the case of k going to zero first, one knows a lot about the response of the free gas because the k = 0 current is basically the momentum. Even if you include electron-electron interactions the k = 0 current has a simple structure dictated by momentum conservation. This is another way to understand how the k = 0 finite omega result is special. Of course, this changes as you say once one introduces band structure or non-translation invariant scattering (like impurities) etc.
From the BCS theory of superconductivity is well known that the superfluid density smoothly decreases with increasing temperature. Annihilated superfluid carriers become normal and lose their momenta on lattice atoms. So if we induce a persistent supercurrent in a ring below Tc and after that slowly increase the temperature, we must observe a decrease in the actual supercurrent, because the density of electron pairs and total supercurrent momentum decrease. However, this supercurrent...
Hi. I have got question as in title. How can idea of instantaneous dipole moment for atoms like, for example hydrogen be consistent with idea of orbitals? At my level of knowledge London dispersion forces are derived taking into account Bohr model of atom. But we know today that this model is not correct. If it would be correct I understand that at each time electron is at some point at radius at some angle and there is dipole moment at this time from nucleus to electron at orbit. But how...
