Line Integral Example - mistake or am I missing something?
3 replies · 2K views
kostoglotov
This is an example at the beginning of the section on the Fundamental Theorem for Line Integrals.
1. Homework Statement
Find the work done by the gravitational field
[tex]\vec{F}(\vec{x}) = -\frac{mMG}{|\vec{x}|^3}\vec{x}[/tex]
in moving a particle from the point (3,4,12) to (2,2,0) along a piece wise smooth curve
Now, I think that there's a mistake in the solution given...but this textbook is pretty good, and plenty of times in the past I've thought it had made a mistake and really I was mistaken.
So, I understand all the concepts (edit: I obviously didn't), all good there. It's here where I'm scratching my head.
[tex]f(x,y,z) = \frac{mMG}{\sqrt{x^2+y^2+z^2}}[/tex]
So, we need to get the scalar function of f, call it the potential function, we know that in a conservative vector field [itex]\vec{F} = \nabla f[/itex], no worries. However, shouldn't it be
[tex]\vec{F}(\vec{x}) = -\frac{mMG}{|\vec{x}|^3}\vec{x} = -\frac{mMG|\vec{x}|}{|\vec{x}|^3}\vec{u} = -\frac{mMG}{|\vec{x}|^2}\vec{u}[/tex]
And so converting the vector form of F into a scalar field from which we can compute the grad vector, doesn't
[tex]|\vec{x}|^2 = x^2 + y^2 + z^2[/tex]
not
[tex]\sqrt{x^2+y^2+z^2}[/tex]
so shouldn't it be
[tex]f(x,y,z) = \frac{mMG}{|\vec{x}|^2} = \frac{mMG}{x^2+y^2+z^2}[/tex]
how would one end up with
edit: both the 6th and 7th editions have the same example...so I'm guessing that I'm missing something.
DEvens said:
Can you work out the gradient of the f(x,y,z) you suggest? Does it give the right force?
No, it gives N not N m.
I'm still not sure what's going on here though. Is it the case that we're NOT trying to just find the magnitude of the gravity vectors on a given domain, but rather searching for some other related function, that will produce a grad vec that when dot producted with a path vector will result in the dimensions that we need in our answer?
I still don't know how they got to their answer.
edit: Oh wait, I think I see what's happening...f(x,y,z) is essentially an antiderivative ?? Thus, we need to be able to get to the grad vec from that f(x,y,z)...??
edit2: yep, that worked, and it made sense...thanks :)
[tex]f(x,y,z) = \frac{mMG}{\sqrt{x^2+y^2+z^2}}[/tex]Standard result: if ##\vec{r} = x\vec{e}_x + y\vec{e}_y + z \vec{e}_z## with magnitude ##r = \sqrt{x^2 + y^2 + z^2}##, then
[tex]\vec{ \nabla} \frac{1}{r} = -\frac{\vec{r}}{r^3}[/tex]
Just look at ##\partial r^{-1} / \, \partial x ## for example.
