Why Are the Terms Squared After Substitution in Green's Theorem Integral?
damndamnboi
i would like to find the area bounded by the curve
(((x^2)/(a^2))+((y^2)/(b^2)))=xy/(c^2)
i used the substitution given x=(ar)cos(theta) and y=(ar)sin(theta)
i get :
(r^2cos^2(theta)+r^2sin^2(theta))^2=xy/(c^2)
thus r^4=xy/(c^2)
substituting x=(ar)cos(theta) and y=(ar)sin(theta) on the right hand side, i get
r^4=(r^2)(ab(cos<theta>)(sin<theta>)/c^2
then r^2=ab(cos<theta>)(sin<theta>)/c^2
then i used jacobian to transform dxdy to drd(theta):
i get abr(dr)(d(theta))
then i carried out the double integral
/ / abr(dr)(d(theta))
but i get 0. please advice
image not working for me.
i'd recommend putting in a little bit of time to learn what you need to about latex to be able to post your problem. knowing latex is important if you intend on publishing research papers, anyway.
thx for telling me about the image not working, i have posted the question in typed form, please take a look. thx.
i just skimmed your work and noticed that you had
<br /> <br /> dxdy = drd\theta<br /> <br />.
the correct relationship is<br /> <br /> dxdy = rdrd\theta<br /> <br />.
<br /> \frac{x^2}{a^2}+\frac{y^2}{b^2}=\frac{xy}{c^2}<br /> <br /> \smallskip<br /> <br /> \mbox{let} x=ar\cos\theta \mbox{and} y=ar\sin\theta<br /> <br /> \smallskip<br /> <br /> (r^2\cos^2\theta+r^2\sin^2\theta)^2=\frac{xy}{c^2}<br />
...wait a minute, why does your first equation not have the terms squared, but then after the substitution, they are squared again?
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
