Linear actuators for mechanical project
The discussion focuses on finding suitable linear actuators for a project requiring fast operation controlled by an Arduino UNO. Key specifications include a minimum speed of 100 mm/s and a load capacity of at least 5 kg, with a control frequency of approximately 10 Hz. Suggestions include potentially overvolting certain actuators from ServoCity to achieve the desired speed and contacting them for further recommendations if continuous operation is needed. A specific actuator from Firgelli Auto is mentioned as a potential fit, along with wiring options using DPDT relays or high-current analog switch ICs for control. The conversation emphasizes the importance of matching actuator specifications to project requirements.
aortucre
Hey guys, I was wondering if you could help me out here. I'm working on a project that needs two fast linear actuators which I'm planning to control with the Arduino logic board, but I can't seem to find anything that suits what I need. Here are the specs.
-Type of actuator: Linear
-Minimum acceptable speed: 100 mm/s
-Minimum acceptable load: 5kg
-Input: Signal from Arduino UNO logic board
-Frequency: Approx 10 Hz
I would appreciate any help that you guys could give me. All the actuators that I've found online are either too weak or too slow.
Dependent on the duty cycle required you could possibly overvolt http://www.servocity.com/html/25_lbs__thrust_linear_actuator.html
these @ 24VDC and get the 100mm/sec required.
If the actuators need to run more than intermittently, I would contact ServoCity about their recommendations. They've been easy to work with for this sort of thing in my experience.
Max travel?
Jupiter6 said:
Max travel?
Around 18"
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
