Proving Linear Transformation for C*A^2
squaremeplz
C is a fixed n*n matrix. Is T(A) =CA^2 a linear transformation on R^(n*n)
Linear transform requirements:
1. T(A + Y) = T(A) + T(Y)
2. T(c*A) = c*T(A)
I'm confused as to how the linear transform requirements apply to matrices. i.e. should I do the proof as column vectors of A i.e.
T(a_1 + a_2 + .. + a_n) = T(a_1) + T(a_2) + ... + T(a_n)
and
T(c*a_1 + c*a_2 + .. + c* a_n) = c* (T(a_1) + T(a_2) + ... + T(a_n))
I think that this is not a linear transformation since scalar multiplication does not hold
i.e. L(c*A) =/= c*L(A)
I'm just looking for a nudge in the right direction and any input is appreciated.
Thank You
2. T(c*A) = c*T(A)
and
Thank You
You don't need to work with the column vectors at all, just the matrices. For arbitrary n X n matrices A and B, what is T(A + B)? Is it the same as T(A) + T(B)?
And since you believe that scalar multiplication doesn't hold for transformation, you should show why T(cA) != cT(A).
Thanks for the quick reply!
1. T(A+B) = C(A+B)^2
= C(A+B)(A+B)
= C(A^2 + 2AB + B^2)
= C(A^2) + C(2AB) + C(B^2)
= T(A) + T(B) + C(2AB)
T(A+B) =/= T(A) + T(B)
2. T(b*A) = C(b*A)^2 : where b is some scalar
= b^2 * CA^2
= b^2 * T(A)
Small correction, otherwise it's ok: Since you deal with matrices, in general AB != BA. So you have (A+B)(A+B) = A² + AB + BA + B².
thanks! got to keep an eye on the details :)
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
