Do the vectors u = (5,1,3) and v = (2,3,6) belong to span(S)?
phys2
The problem is : Let S = [ (1,-1,3) , (-1,3, -7) , (2,1,0) ]. Do the vectors u = (5,1,3) and v = (2,3,6) belong to span(S)
So span means that I could take linear combinations of u and v and they should end up giving (1,-1,3) , (-1,3,-7) and (2,1,0). Right?
I could take x [5 1 3 ] + y [ 2 3 6 ] = [1 -1 3] or [-1 3 -7 ] or [2 1 0 ] (btw i meant to write [ 5 1 3] as a column matrix but I am not sure of how to using Latex. So anyway, is what I am trying to do correct? Is that what it means for the vectors to span S?
Thanks
No, it's the other way around.
Span(S) is the set of all linear combinations of the vectors in S. u is in Span(S) if there are constants a, b, and c for which a(1, -1, 3) + b(-1, 3, -7) + c(2, 1, 0) = u.
Similarly for v.
Thanks
Put your vectors from S into matrix form, augmenting them with either u or v ( You'll have to do both at some point so pick one at a time ).
Solve the corresponding system and check if the following system is linearly independent or dependent.
If the system is dependent for your choice of u or v, then you can conclude that the vector is not in the span of your set. Otherwise if your system is independent, you can exhibit a unique solution for your system implying that your vector IS in the span of your set.
Similarly for v.
Ahh I see thanks
Yes, it works out...thanks
