Linear combination and orthogonality
ThomMathz
Member warned about not using the homework template
Given the non-zero vectors u, v and w in ℝ3
Show that there is a non-zero linear combination of u and v that is orthogonal to w.
u and v must be linearly independant.
I am not really sure at all. But I have done this:
This is a screenshot of what I have done. Basicly, I assumed in the end that u and v are not orthogonal, and then I chose some suitable substitution for u and v, and ended up with zero when dotting them with w. Evverything is much appreciated and especially if you have another solution that is better or correct, because I think mine is not that good though.
https://gyazo.com/707e7c168a1c1a15166fd71be4ae7a81
I'm pretty sure the claim is not correct. Consider the vectors
u=(5,0,0)
v=(5,1,0)
z=(5,0,1)
The set is linearly independent, but there is no linear combination of u and v that is orthogonal to w.
u=(5,0,0)
v=(5,1,0)
z=(5,0,1)
If by z you mean w, then the statement above is false: the linear combination c*u-c*v = (0,-c,0) is orthogonal to w = (5,0,1).
The result is true, but I will not look at the OP's screenshot (only at a typed version).
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
