Linear Expansion of Solid problem
To determine the temperature at which an aluminum shaft will fit through an aluminum ring, the problem involves calculating the necessary cooling of the shaft. The initial diameters are 0.07 m for the ring and 0.07003 m for the shaft at 5 degrees Celsius. The coefficient of linear expansion for aluminum is 2.4 x 10^-5. The calculations show that the final temperature needed for the shaft to fit is -12.85 degrees Celsius, which is derived from the difference in diameters and the linear expansion formula. Errors in sign and exponent handling were noted during the calculations, emphasizing the importance of careful mathematical operations.
toddler
There is an aluminum ring, .07 m in diameter at 5 deg. C. There is also an aluminum shaft whose diameter is .07003 m in diameter at 5 deg. C. What temp. should the shaft be cooled such that the ring will fit over the shaft.
/\L = Coefficient of Lin. Expansion (Original Length) /\T
step 1) .07 - .07003 = 2.4 x 10^-5 (.07003) (5 - Tf)
* The original length is .07003 since is what is being cooled to eventually reach .07 m. Also, the Coefficient of Lin. Expansion for Aluminum is 2.4 x 10^ -5
step 2) -3.0 x 10^-5 = 1.681 x 10^-6 (5 - Tf)
step 3) -3.0 x 10^-5 = 8.405 x 10^-6 - 1.681 x 10^-6 Tf
now when i solve for Tf, it is not coming out to -12.85 deg. C, which the book states is the answer...so I'm assuming there is an error somewhere, or a few places...any help would be appreciated , thanks
Your step 3 is OK. Check you didn't make a mistake with the signs or the exponents. Multiplying everything by 10^6 might help.
-30 = 8.405 - 1.681 Tf
EDIT:
Oops, P3X-018 is right. I made two mistakes which canceled out and gave me the right answer. Need more coffee...
I assume you get a reversed sign? When you calculate the temperature difference you use "initial temperature - final temperature" you need to use the same order about the difference in the diameter, that is "inital diameter - final diameter". You do it reversed for the length, what is the initial diameter?
Linear expansion
consider
for variation in lenth Delta L for any variation in temp Delta T is
Delt a L = Coeff of Linear expansion * Original Length * Delta T
or
Delta T = Delta L / ( C of L exp * Original Length)
in the present case
delta L = 0.07003 - 0.07000 = 0.00003
then delta T = 0.00003 / ( 2.4 * 10 ^-5 *0.07003)
= ( 3 * 10^5)/ (2.4 * 7003)
= 300000/(1687.02)
=17.849
since delta L is negative, delta T also will be negative , which means
delta T = - 17.849
or -17.85 = final temp -original temp = Ft - 5 or
FT= -12.85
hope this is clear
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
9K
