Linear homogeneous D.E. with constant coefficients - known solutions
etf
My task is to find Linear homogeneous D.E. with constant coefficients which has solutions:
$$\\\varphi 1(x)=x^2,\varphi 2(x)=e^{-3x},\varphi 3(x)=cos(5x)$$ Any idea?
I think that here we have root $$\\\lambda 1=0$$ with multiplicity 3 (from $$\\\varphi 1(x)$$), root $$\\\lambda 2=-3$$ with multiplicity 1 (from $$\\\varphi 2(x)$$).
I assume you mean second order.
The solution ##x^2## should come from a Cauchy Euler equation I believe. So I think you need to find an equation of that form by multiplying the roots together to "work backwards" to the indicial equation.
Likes 1 person
It is possible to have \varphi_1(x) = x^2 as a solution to a linear homogeneous equation with constant coefficients. In addition, a linear homogeneous differential equation has as many linearly independent solutions as the order of the equation. Since the 3 functions you listed are linearly independent, the equation we are looking for must be at least of order 3.
As a hint, note that any linear combination of the solutions must also be a solution. Thus, the 3-parameter family of functions \varphi(x) = C_1x^2 + C_2e^{-3x} + C_3\cos(5x) is a solution to the unknown differential equation. As a further hint, try taking this solution's derivatives. Can you find a combination using constant coefficients that is homogeneous?
Likes 1 person
You're missing \cos(5x) = (e^{5ix} + e^{-5ix})/2.
Thus the auxiliary equation must be a polynomial with roots 0 (with multiplicity 3), -3, 5i and -5i.
Likes 1 person
Wow, I totally forgot equations higher than second order existed ^_^.
My bad.
I calculated characteristic polynomial as $$\\(\lambda -\lambda1)^{3}(\lambda-\lambda2)(\lambda-\lambda3)(\lambda-\lambda4)=(\lambda-0)^{3}(\lambda+3)(\lambda-(0-5i))(\lambda-(0+5i))=...$$
$$=\lambda^{6}+3\lambda^{5}+25\lambda^{4}+75\lambda^{3}$$ so D.E. is $$\\y^{(6)}+3y^{(5)}+25y^{(4)}+75y^{(3)}$$
It looks correct. The result is the same using Slider142's hint.
ehild
Except that that isn't an equation.:frown:
Oh, =0 is missing! I did not notice.:blushing:
ehild
Forgot to write = 0 :smile:
Here is another one (this one is not with constan coefficients):
Find linear homogeneous second order D.E. which has general solution $$\\\varphi (x)=C1\frac{sinx}{\sqrt{x}}+C2\frac{\cos{x}}{\sqrt{x}}, x>0$$
Any idea?
What is the differential equation for y(x)=√(x) φ(x)?
ehild
I found it. $$\\-\frac{1}{x}y''-\frac{1}{x^{2}}y'+(\frac{1}{4x^{3}}-\frac{1}{x})y=0$$
Congratulation!
Have you used my hint? It is very easy with that.
ehild
To be honest, I didn't understand your hint :(
I solved it using Wronskian:
$$\\y1(x)=\frac{\sin{x}}{\sqrt{x}},$$
$$\\y2(x)=\frac{\cos{x}}{\sqrt{x}},$$
$$\\W(y1,y2)=\begin{vmatrix}
y1(x) & y2(x) & y \\
y1'(x) & y2'(x) & y'(x) \\
y1''(x)& y2''(x) & y''(x)
\end{vmatrix}=0$$
However, this is a little bit complicated.
Multiply by √x:
\sqrt{x}\varphi (x)=C1\sin(x)+C2\cos(x)
Define a new function ##y(x)=\sqrt{x}\varphi (x)##. The general solution of a linear homogeneous differential equation for y(x) is ##y(x)= C1\sin(x)+C2\cos(x)##. But that is the solution of the well known differential equation ##y''+ y=0 ##.
Find the second derivative of ##y(x)=\sqrt{x}\varphi (x)## in terms of x and φ and substitute into the equation ##y''+ y=0 ##...
ehild
Wow :smile:
Your method is definitely much better :)
Thanks!
