Linear independence of sin (x), cos (x) and 1, proof
Luka
What would be the best way to show that functions f(x)=1, g(x)=sin(x) and h(x)=cos(x) are linearly independent elements of the vector space \mathbb{R}^{\mathbb{R}}?
I know that the linear independence means that an expression like \alpha \mathbb{x}_1 + \beta \mathbb{x}_2 + \gamma \mathbb{x}_3 = \mathbb{0} is true only for \alpha = \beta = \gamma = 0 where x_1,...,x_3 are vectors and \alpha, \beta and \gamma are scalars of the vector space.
I think that the proof might look like this:
\alpha sin(x)+ \beta cos(x)+ \gamma 1=0
If x=0 then sin(x)=0. Therefore, \beta=0 and \gamma=0, but \alpha might be different than zero, and the above-mentioned expression still equal to zero.
Your attempt is a good one. So assume that there are \alpha,\beta,\gamma such that
\alpha f + \beta g+\gamma h=0
That means that for ALL x must hold that
\alpha+\beta\sin(x)+\gamma \cos(x)=0
This holds for all x, so try to pick some good values for x.
You already tried x=0, this gives us that necessarily
\alpha+\gamma=0
(and not \alpha=0,\gamma=0 as you claimed).
Now try some other values for x. For example pi or pi/2 ??
PS excuse me for using other \alpha,\beta,\gamma as in your post.
For x=\pi, we get \gamma - \beta = 0 which means that \alpha can be of any value, and the expression still equal to zero. Then those elements (f(x), g(x) and h(x)) would not be linearly independent according to the definition of linear independence. I think that we need all three scalars to be zero to prove the linear independence: \alpha =0, \beta =0 and \gamma = 0. In other words, sin(x)\neq 0 and cos(x)\neq 0.
For x=\frac{\pi}{3}, we get \frac{\sqrt{3}}{2}\alpha +\frac{1}{2}\beta + \gamma = 0, which means that \alpha, \beta and \gamma must be equal to zero for the expression to be true.
Why should this imply that \alpha,\beta,\gamma are all zero?? It doesn't.
It does if we want to prove the linear independence (because of the definition itself). I'm worried about the fact that not all x satisfy the conditions sin(x)\neq 0, cos(x)\neq 0 that allow us to prove it.
Because you want them all equal to 0, you simply declare that
\frac{\sqrt{3}}{2}\alpha+ \frac{1}{2}\beta+ \gamma= 0?
Looks like you are assuming what you want to prove.
What about \alpha= 0, \beta= 2, \gamma= -1?
To prove that 1, sin(x), and cos(x) are independent, you want to prove that the only way you can have \alpha (1)+ \beta(sin(x))+ \gamma(cos(x))= 0 for all x is to have \alpha= \beta= \gamma= 0. But that is what we want to prove- we cannot assume it.
Since that is true for all x, it is, in particular, true for x= 0, we must have
\alpha+ \gamma= 0
And, for x= \pi/2, we must have
\alpha+ \beta= 0
Finally, for x= \pi, we must have
\alpha- \gamma= 0
Solve those three equations for \alpha, \beta, and \gamma.
