Calculate Liquid Flow Rate in Isolated Pipes
This discussion focuses on calculating the flow rate of crude oil leakage past closed valves in isolated pipe sections. The user describes a scenario where they isolate a pipe section with a volume ranging from 3 to 18 cubic meters, bleed pressure down to 10 psi, and observe pressure rises of 20 psi per minute. To determine the leakage rate in liters per minute, the user seeks a formula that incorporates variables such as isolated pipe volume, time, pressure rise, and mainline pressure. The consensus is that laboratory tests on valves are necessary to measure flow rates based on pressure differentials and valve closure fractions.
  • Understanding of fluid dynamics principles
  • Knowledge of valve operation and sealing characteristics
  • Familiarity with pressure measurement techniques
  • Experience with laboratory testing methods for flow rate analysis
  • Research flow rate calculation formulas for pressurized systems
  • Learn about valve testing procedures to assess leakage rates
  • Investigate the impact of pressure differentials on valve performance
  • Explore fluid dynamics simulations for various pipe sizes and conditions
Engineers, maintenance personnel, and safety professionals involved in pipeline operations, particularly those managing crude oil transport and valve integrity assessments.
atc250r
Hello, my first post here. I encounter a situation frequently at work that I'd like help with so here it is...
When I isolate a particular section of pipe (by closing valves), I then bleed off the pressure in the isolated section (volume of isolated pipe varies from 3 cubic meters up to about 18 cubic meters). I often bleed the pressure down to about 10psi. Then I observe a digital pressure gauge to confirm that the closed valves are holding. There is often upwards of 300-800 psi of crude oil in this pipe. Occasionally, the pressure in the isolated section climbs slowly 20 psi/minute (give or take). Sometimes the valves hold completely and no pressure rise occurs in the isolated section and then we're all happy. But when the pressure does climb, how can I get a "liters/minute" flow rate so that I know how much product will be leaking past the valves after I have drained the isolated section and I open that isolated section for maintenance. I need to know if the leakage is manageable or not. I assume the variable numbers you need to know are:
isolated pipe volume: 5 cubic meters
time: 60 seconds
pressure rise: 10 psi
mainline pressure: 500 psi
incoming flow rate (leakage past closed valve): ?? Liters/minute
Is there a formula for this that will work on various sizes of isolated pipe sections? Maybe mainline pressure is irrelavent? Do you need more info?
Thanks!
time: 60 seconds
Thanks!
It seems to me that you need to do some off line laboratory tests on a valve to measure the flow rate as a function of the pressure difference and fraction valve closure.
If the valve is working as it should, there would be zero leakage through it, no matter the pressure differential acting upon the valve. Certain valves in the system seal 100%, others that are older, do not. When they don't seal 100%, it would be really nice to know how many litres/minute will be leaking past the valve once the system is "opened".
  • · Replies 30 ·
  • · Replies 35 ·
17K
  • · Replies 48 ·
